Custom User Title
rammstein's Avatar
arrrrrrrgh
So having fixed my fuel leak with a new check valve and seals, I drove about 100 incident free miles. Just now my fuel pump started making bad, loud noises. No other adverse symptoms (no stumbling). What gives?
Old 10-31-2004, 07:08 PM
fast924S's Avatar
Send a message via AIM to fast924S
How much fuel is in the the tank???
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-31-2004, 07:35 PM
Custom User Title
rammstein's Avatar
Just filled the tank this morning.
Old 10-31-2004, 08:12 PM
fast924S's Avatar
hmmmmmm How old is the pump??? How loud is it??? On my 87 924S you can hear a high pitch humming outside the car
Old 10-31-2004, 08:30 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
I had one that got really loud, and it eventually gave out, sorry that really sucks! My only suggestion to you is that when you install a new or rebuilt one, to put a filter before the fuel pump. This keeps it from getting a bunch of junk from the tank in it. Easy to do, you can grab one at autozone for a few bucks.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-31-2004, 09:00 PM
Custom User Title
rammstein's Avatar
Just to note, its not the standard fuel pump hum. Its quite a loud moaning, which can be felt (the vibes).
Mac- I assume you are referring to the pre-filter thingy?
Old 10-31-2004, 10:02 PM
Custom User Title
rammstein's Avatar
Is the solution to buy a 911?
Old 11-01-2004, 11:04 AM
fast924S's Avatar
I would just get a new fuel pump and hold onto it until this one craps out
Old 11-01-2004, 02:21 PM
AFJuvat's Avatar
Fuel pump crapping out.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-01-2004, 04:20 PM
vott does ziss do?
ronin's Avatar
(casually checking the 944 posts list -
find one titled "arrrrrrgh" -
check author's name -
read Rammstein -
laugh out loud -
check to see what trouble he's gotten into today)
just glad you're toughing it out. hang in there!
Old 11-01-2004, 11:07 PM
Manute's Avatar
I can´t solve your problem but I can say I´m going to a Rammstein concert next 10th.
Oh, and I can say "Hi Ronin!" too...
85´5 951
Old 11-01-2004, 11:28 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Damn, I wish those guys would tour over here. They're freakin awesome =)
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-02-2004, 08:22 AM
Custom User Title
rammstein's Avatar
OK- it MUST be bad
Started the car just now, it is stumbling really badly. When I hit the gas, it stumbles a lot, and I am getting nasty smoke from the pipe. SO, I guess I need a fuel pump.
Where should I buy it? The dealer quoted $309, so they are out. Pelican has it at ~$210, but it looks wrong because there's no rubber casing.
See here:
www.pelicanparts.com/catalog/images/nori_images1/FuelPump94460810204.JPG
God hates me. I know it now.
Old 11-02-2004, 01:47 PM
Custom User Title
rammstein's Avatar
and I almost forgot-
is this the correct part # for the pre-filter thingy?
928 201 187 02
Also- how can I change the pre-filter without draining the gas? I mean, to change the pump I can just clamp the gas hose, but the change the prefilter it looks bad....
Old 11-02-2004, 01:50 PM
rammstien, the prefilter i was refering to is not the same as your regular fuel filter, I was talking about an autozone part, you just cut the fuel line jsut past where it comes out of the tank and put in a filter, and use 2 clamps to hold it in. This keeps all the crap in your tank out of the fuel pump. but also replace the fuel filter while in there if you haven't. You will get some gas in the face, just be careful and de-pressureize the fuel system first, then use a clamp to clamp the line just outside of the tank.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 11-02-2004, 01:55 PM
Custom User Title
rammstein's Avatar
I think I follow. I replaced my BIG fuel filter about 2 months ago.
There's also a filter behind the hose that goes from the tank to the pump.
Old 11-02-2004, 02:10 PM
oh okay, on my car there isn't a faactory one of those. If I were you I would either replace that or just go the autozone cheapo route. Someone else that has done this before should chime in. In my opinion it keeps the crud from your fuel tank out of the fuel pump, keeping it from failing so quickly.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 11-02-2004, 02:29 PM
