Replacing alternator
I was wondering if the 115 amp alternator used in 85/2 and later 944's would fit directly in a 85/1 944? Are the mounting brackets the same in both years?
Old 12-18-2004, 10:51 PM
Granite 944's Avatar
No, as I remember it, they are different, as is the AC compressor and mount also. But I think it might be usable if you also change the large mount bracket with it, but then I'm not sure if you'll get the AC to mount back up.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 12-18-2004, 11:13 PM
SoCal Driver's Avatar
Pulley is different too. Has an extra V to it making six total. So you have to either change the pulley on the alternator to the five groove of change the pulleies on the engine and on the AC compressor to the six grooves.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-19-2004, 04:29 PM
