Autobahn Garage
Power steering issue, what's the problem???
I have a 84 944, the power steering make a growning noise and slips the belt. There are no leaks, and I drained the fluid out and replaced in and it still does the same thing. Yes I used ATF, it foams the oil in the reservoir. The fluid is not low, I have checked it cold as well as hot. Could this be the pump? The oil I removed was a little dirty but I have seen worse. Any ideas??
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-01-2005, 02:04 PM
AFJuvat's Avatar
You are sucking air somewhere in the system check under the boots on teh rack and see if you are leaking there.
Otherwise, your pump is on its way out.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-01-2005, 06:14 PM
Autobahn Garage
Thanks I will look at it today,
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-02-2005, 06:12 AM
