fast924S's Avatar
Send a message via AIM to fast924S
What type of engine is this??
I got this pic off of rennlist, Some masrati race car. AT first looks it seems to be a 4 cyl, I see it has 2 carbs and 4 intake runners (they could split inside the runner)
The thing that throws me off is what I believe to be the spark plug wires, there are 8 of them, so I was like maybe its got dual plugs, but at a closer look not all cylinders have 2 spark plugs, only the middle ones do. Also what are the chrome pipes that go into the head, I dont believe they are exhaust maybe some type of coolant of oil passages. Can some one please clear my head and help me figure out what is going on, maybe Im just stupid or maybe Im missing something. Any ideas??
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-08-2005, 03:26 PM
It has eight plugs, hemi head and the plugs go in at an angle, therefore the gap between them. Think it looks a lot like the Maserati Birdcage type of engine. The chrome pipes are coolant pipes.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-08-2005, 04:42 PM
Originally posted by Britwrench
It has eight plugs, hemi head and the plugs go in at an angle, therefore the gap between them. .
I'm seeing the same thing that fast sees. There appear to only be 6 plugs, 1 plug for cyl's 1 and 4, and 2 plugs for cyl's 2 and 3....
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 06-08-2005, 05:03 PM
Verruckt's Avatar
Are you thinking of installing one in your 924S, Fast? ;-)
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 06-08-2005, 05:10 PM
I see 8.
1 and 8 are alone.
2&3; 4&5; 6&7 are pairs and as Brit says 'go in at an angle'
Tom
Early '85 944
Old 06-08-2005, 05:24 PM
Originally posted by carsontc
I see 8.
1 and 8 are alone.
Ah, I see it now..... What I was seeing were the pairs per cylender were together.... They are seperated, now I see 8.
They call it a twin plug motor from what I'm reading. MT4 Twin plug possibly.
Jack
Old 06-08-2005, 05:37 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
y do 1 and 8 only have 1 plug?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 06-08-2005, 06:00 PM
fast924S's Avatar
I still cant figure out what the hell is going on
Old 06-08-2005, 06:02 PM
fast924S's Avatar
Ok I zoomed in and Brit is correct, It seems like its a 4 cyl with 8 plugs, The plugs seem to be at the far ends of each cylinder and they do go in at angles. hmmm what a weird idea
Old 06-08-2005, 06:10 PM
Ornery Bastard
See attached.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-08-2005, 06:12 PM
fast924S's Avatar
Got it, I wonder what the displacment of that engine is, I mean whats the purpose of a dual plug unless you have a very large displacment engine or a very dense mixture, right??
Old 06-08-2005, 06:42 PM
my924gtc's Avatar
I'd say that is at least a 3.0L motor given the fact that it is being feed by no less than 48mm DCOE Webers, might even be 50's.
Old 06-08-2005, 07:30 PM
Send a message via AIM to operationcougar
displacement doesnt constitute the dual plugs, you can get a more efficient burn off of any sized engine with dual ignition (1.8L and 2.0L '86 nissan 200sx -RIP-)
95 - BMW 740i (daily driver)
02 - kawasaki mean streak (nice weather driver)
RX-7 built of other RX's (and a good place to throw money) (sold)
z31 300zx vg30det+ (new money sucker)
Old 06-09-2005, 12:00 AM
Dual plugs are also used for higher compression engines...like some of the 911's
Jason
Jason Judd
Old 06-09-2005, 04:48 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
IT looks like it may be a modified version of one of the engines on this page:
http://homepages.tesco.net/~enrico/image/home11.htm
This page has more of their engines, but bigger displacement ones:
http://homepages.tesco.net/~enrico/image/home12.htm
Maybe This:
ENGINE TIPO 4CF2
Year of production: 1952-1953
Straight 4-cyl 1994.9 cc engine
DOHC with four valves per cylinder
Bore 88mm and stroke 82mm
Compression ratio 12.0:1/13.5:1
Power output 182/195bhp @ 7000/7500 rpm
Induction system by two Weber DBO carburettors
Later by direct fuel injection.
or THis:
ENGINE TIPO 60
Years of production: 1959-1960
Straight 4-cyl 1990.2 cc engine
DOHC with two valves per cylinder
Bore 93.8mm and stroke 72mm
Compression ratio 9.8:1
Power output 200bhp @ 7800 rpm
Induction system by No 2 Weber 45 DC03 carburettors.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 06-09-2005, 07:11 AM
Pretty nice. 2 liters, two valves, no turbo, and 200 hp. Of course, you have to wonder if that's gross power, not SAE net. Still, it makes more power than the 944 engine, with less displacement
Old 06-09-2005, 07:37 AM
Ornery Bastard
I'll bet that it doesn't last nearly as long either.
Comparing a racing engine to a street engine doesn't work so well.
Aaron
Old 06-09-2005, 04:04 PM
fast924S's Avatar
Both of those engines flow more and have higher compression ratios, thats why there is more HP
Old 06-09-2005, 05:50 PM
fast924S's Avatar
Cool FR has the other pic and named that motor
Old 06-09-2005, 07:46 PM
i was just going to add, look at the wheel and tire combo, prolly not something thats up to date
Old 06-09-2005, 10:57 PM
