Cars & Coffee Killer
Dash Electronics
I'm pretty sure I have a loose or corroded connection behind the dash gauges. When I got the car, the odometer didn't work. I pulled the gauge cluster and inspected the odometer, I didn't see anything wrong so I reinstalled it. The odometer started working again. It worked until I tried to reset the mileage counter.
This weekend I was driving the p-car and as I pulled out of the driveway, I noticed the speedometer was not working. I tapped on the gauge cluster and it came back to life. When idling, my oil pressure gauge bounces around quite a bit (between 3 and 5). I figure the connections on the back of the gauge cluster could stand a cleaning. Any suggestions on the best way to clean the contacts? I can't think of a way to clean the contacts on the harnesses that hook up to the back of the gauges.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Just make sure all of the srews are tight (do not overtighten) and clean them with rubbing alcohol.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
has all kinds of contact cleaners...
Tom Early '85 944 |
Did you ever take care of this? On my car, it seems as though the speedo needle is "sticky". It will work with a little tap, or after a little higher speeds.... I noticed the Odometer still rolls even if the needle doesnt move though.....
Any tips or hints? |
meister member
You can try a pencil eraser or some fine emery cloth.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
That Guy
I get that same problem on occasion with the speedometer. I cleaned all the contacts with a pencil eraser but still have the issue. Frankly its not big enough a concern that i want to take everything apart again.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
I pulled and cleaned all of the contacts with rubbing alcohol. The oil pressure is much less "bouncy", but the odometer still does not work. At some point I will pull it again and check the gears on the odometer (I did this the time before last and they all checked out).
Contact cleaner pen, $5 at Radio Shack. Worked wonders on my car...
