A.K.A. GOB Bluth
carolinatrophy's Avatar
Porsche Crest 924 Turbo header panel on 951
Has anyone fitted a factory 924 Turbo header panel (with the four oval vents) to a 944 Turbo? I just bought a used 924 Turbo header panel for the swap, but it hasn't arrived yet and I am wondering if the front radius has a diffferent curve, or perhaps if the headlamp covers are a slightly different shape...
Or is it a direct swap?
Anyone know what I'm in for when it comes to fitting this thing? If not, I'll post me experienced soon...
Old 01-24-2006, 08:08 AM
Crew Chief
prooutlaw's Avatar
The Header panel and the Headlamp covers are a different shape and will not align with the Turbo Bumper.
Hate to be the Bearer of bad news.
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 01-24-2006, 08:33 AM
A.K.A. GOB Bluth
Grrrr... I have the seen this swap on other 944 Turbos. Any idea how it is done? Do you think they are using just the vents, and cutting out holes in the stock header panel?
Paul Misencik
Huntersville, NC
Old 01-24-2006, 08:36 AM
Crew Chief
prooutlaw's Avatar
Either they are just using the Vents or there are Fiberglass panels available.
Do like me cut a rectangular hole and round the ends on the Turbo Panel
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 01-24-2006, 09:13 AM
A.K.A. GOB Bluth
Yeah, except I specifically want a very "factory" style of appearance, and the 924 Turbo vents give that. I'm not a fan of the looks of the aftermarket header panels.
I'll see what I can do with this thing when it arrives...
Paul Misencik
Huntersville, NC
Old 01-24-2006, 09:27 AM
Crew Chief
prooutlaw's Avatar
Ok, good luck
You can always ride up and look at mine , it's not that far
Herbert B.
GruppeB #093
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'86 951
'87 944
Old 01-24-2006, 09:59 AM
Eldorado's Avatar
you want a 951 with a factory appearance so you're installing a 931 style nose panel?
ok...
well, if that's the look you're after, i suggest just cutting the holes yourself, or buy another 951 nose piece and cut those and paint to match.. might be slightly more expensive in the end, but at least you wont end up with a munched up 951 nose piece and no replacement.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-24-2006, 10:47 AM
tifosiman's Avatar
Actually, you can cut the section of the 931 header panel out that has the four vents in it (so you have a long rectangular piece), then cut the same sort of rectangle in the 951 header panel and graft that piece in there. You'll have to do a little finish work to make it look correct, but then the vents, the curves of the openings, and the vent supports will be correct-looking. There was a guy on another forum that did this and it looked good.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 01-24-2006, 01:38 PM
winter-hater club member
nynor's Avatar
my .02:
just have holes cut in the existing panel and call it a day. cheap, easy, guaranteed to fit.
"COOL PRIUS!" - Nobody Ever
Old 01-24-2006, 01:53 PM
Capri22racer's Avatar
Yeah, I have seen that done too. Pretty easy for body shop guy that welds and knows what he's doing.
The problem with just cutting holes a calling it day is it looks bad and cheesy. You would need to roll the edges and fabricate the mounting tabs. See pic.
1980 924 Carrera GT
1991 944S2
1984 944
Old 01-24-2006, 02:11 PM
Ornery Bastard
Which is exactly what I plan on doing when I finally get around to repairing my current header panel (has a dent in it from a parking lot incident when the PO had it parked somewhere). I figure that since I'll have to have the header panel off the car and re-painted anyway I might as well have someone graft the 931 vents into it as well.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 01-24-2006, 07:29 PM
