Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
ae1969's Avatar
Send a message via ICQ to ae1969
Project Update - Part III
Part II
So........ The engine is now ready.............
JustinL and I managed to crank the car over...... We pulled the fuse on the fuel pump and cranked the car to ensure all systems were powering and MS was seeing all the sensors.....
It looks like the EDIS triggering setup works. We are receiving a PIP signal ....thus the VR sensor is picking up the pulses. Hoooray.
No wires melted so the newly created harness is working.
We fired up the MS and brought up the real time display and everything was checking out.
The only problem was that EDIS was not communicating with Megasquirt. SOOO we are pulling out the MS assembly troubleshooting to make sure everything was setup properly on it. We will probably fire it up this weekend!
Here is where we are now....
Things remaining......
- vaccum line to go to the Megasquirt and t-ing to the boost guage
- ordered a new set of high resistance 55 lb injectors. (P.S siemen 55lb for sale now with resistor pack) if anyone is looking for a set
- found my wideband display finally!!!!
All systems are go.
Alex
PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi
79' 924 (R.I.P)
Old 05-03-2006, 11:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Holy Lindsay Racing, Batman.
I admire this project. And I'm not just buttering you up because I might need help with the 951 engine I may be buying...
Garnet Red 1986 Porsche 951: Land Rocket Dark Silver 2009 Mini Cooper S ("Mighty Mouse"). Daily Driver Alpine White 1983 Porsche 944 - SOLD, and missed. Guards Red 1984 Porsche 944 - One-time parts car, SOLD.
CURRENTLY DRIVEABLE: Porsche[*] Mini[*]
Old 05-03-2006, 11:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Writer/Teacher
CJFusco's Avatar
I just re-acclimated myself with your project, looking over your past two threads. This is very similar to what I hope to accomplish.
Not to hijack your thread, but...
Basically I will PROBABLY have a 86 951 motor, going into a 83 944. While I build the engine, I will still be driving my 944 with its NA engine. Once the engine is built, I will do the swap and sell my NA engine.
I am still unsure of what I might upgrade. The engine is a full longblock from oil pan to cam tower, including the head. Not included is the intake manifold, the turbo, the oil cooler, and wiring. I will definitely replace belts, just to be on the safe side. I know that used intakes can be found for cheap... unless I am talked into getting the upgraded Lindsey unit.
Turbos? I haven't even given much thought to this yet; I want to get the engine before I get into details.
The big hurdle for me might be the wiring harnesses. I know zip about electronics.
Great project, Alex. At least now I know it can be done. I'll point the finger at you as soon as the purists start screaming "JUST BUY A 951!"
Old 05-03-2006, 11:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
ae1969's Avatar
The real beauty of this CJ.............. This stand alone can be had for cheap. The megasquirt could be the best upgrade for any NA. It would allow for many future modifications................
The dilemna with any NA conversion, modification was the ability to control timing, fuel etc....
You can slap superchargers and whatever into an NA engine (although there are much better things you can do if you start with a turbo block).......... in the end you need the ability to fine tune the setup.
AFPR, massaging the stock motronic, extra injectors and band aiding it all will only lead to one thing.
BOOOOOM.
The 83' will have some other issues (fabricate a number of things) but you can't go wrong with a turbo block. Many fuel/timing maps out there to get you started..........after that is a lot of tuning. But thats half the fun.
On the 86 everything bolts on.....just a hand full of differences.
If I had an 83 I would look at putting the turbo on the passenger side. YOu would need a number of modifications but worth the hassle.
I mapped out the complete wiring for this setup ......it basicly plugs right into the stock engine bay plug. Quite happy about that accomplishment.
Alex
79' 924 (R.I.P)
Old 05-03-2006, 12:54 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
cold starter
JustinL's Avatar
It's getting soooooo close now. There are just a few things to tighten down, and then sort out the tach signal and in theory it should just start up. After that, I foresee a bunch of time sitting shotgun with a laptop.
It's so nice working on the car that you don't have to worry about wires and vacuum hoses breaking if your language is too harsh.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
87 944 n/a: Microsquirted PnP, 284K miles, Fresh engine, Mild suspension upgrades, mildly lightened.
Old 05-04-2006, 07:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
ae1969's Avatar
I think I figured it out........... had 2 short out two things ......and remove a capacitor .......and couple of diodes...... and I think we are ready to go!
Also injectors! are in!...... gotta go pick them up.
So everything is here.............. this weekend ........ it will run!
BUHAHAHAHAHAHAHA
Alex
79' 924 (R.I.P)
Old 05-04-2006, 09:04 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
Writer/Teacher
CJFusco's Avatar
Good work, keep us posted.
Old 05-04-2006, 09:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Alex, was this the 944 I saw in front of Eurasia last week smelling of fresh paint?
'84 924 Daily driver.
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project.
'77.5 924 - beach jalopy, still going!
Some wrecks
Old 05-04-2006, 10:01 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
