Consistent fuel problem
For about a year my 78 924 has had a problem after running for a while- It starts and runs fine cold, but after 20 minutes or so it begins to run like it's dropping cylinders, and finally it just won't continue to run. For a long while I figured it was an ignition problem, but lately I am interpreting it as starved for fuel. I can't think of any heat-related issues that would cause this problem- any ideas? The fuel pump itself is about 2 1/2 years old, or about 3000 miles. Same with the fuel filter. Thanks!
Chuck Gass
'78 924
Old 07-27-2006, 03:44 PM
AFJuvat's Avatar
Warm up regulator
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-27-2006, 06:16 PM
Originally posted by AFJuvat
Warm up regulator
AFJ
Okay, so it's the warm-up regulator. Next question: Why does mine only have one fuel line going to it? The other appears to have had a vacuum hose attached to it by the previous owner, which doesn't look to be how it's suppposed to work. Can someone tell me where the fuel lines are routed to/from so I can try to troubleshoot it?
Thanks.
Chuck
'78 924
Chuck Gass
1978 924
Old 07-29-2006, 04:44 PM
