a/c/ help
Just added on can of r134a to my empty system. I started the car, put the air on high and emptied the can into the system. The car ran funny for a few seconds and stalled and now it won't start.
any ideas?
TIA
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 08-02-2006, 11:32 AM
bearone2's Avatar
pull the fuse for the a/c and see if it'll start.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-02-2006, 11:35 AM
No it deosn't. It sounds like the battery is drained though. I tried to start it before pulling hte fuse and it cranked slowly a few seconds and then got weaker. I then pulled the fuse and it cranked the same way. Very weak. I am getting more then a click now though.
Dan
1988 Turbo S (Red)
Old 08-02-2006, 11:43 AM
Cars & Coffee Killer
legion's Avatar
Could be just a coincidence that your battery is going.
Could be a short somewhere...
Hook a multimeter in serial with the battery and see how many milliamps you are drawing. DON'T TRY TO START THE CAR!
You may have to move the key to the "accessory" position and back to see the draw.
5 liters of VVT fury now
-Chris
Old 08-02-2006, 12:03 PM
Have a multimeter what do you mean in serial?
Dan
1988 Turbo S (Red)
Old 08-02-2006, 12:05 PM
Just jumped the car and it is running. started right up
Dan
1988 Turbo S (Red)
Old 08-02-2006, 01:03 PM
Ran for about 15 minutes and died. Seems dead, not even a click when I try to start it.
Dan
1988 Turbo S (Red)
Old 08-02-2006, 01:07 PM
RM512's Avatar
Sounds like your altenator is bad.
Old 08-02-2006, 02:06 PM
is there a way to tell for sure? Need car by sunday
Dan
1988 Turbo S (Red)
Old 08-02-2006, 02:07 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Battery is completely dead. I would unhook my battery cables and put a charger on the battery. Then put the amp meter in to see what the current draw is. Hook one side of the multimeter to the positive post of the battery using aligator clips and the other side to the positive battery cable while it is NOT attached to the battery and read the meter to see how many amps you are drawing. Document that and then put the a/c fuse back in and read again. Let us know both numbers. As Legion already said...please do NOT try and start the car in this configuration.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 08-02-2006, 02:10 PM
Here's the deal. I jumped the car and it started. I noticed the gauge on the dash read less then 12 volts where it used to read more then 12 volts. When i disconnected the jumper cables the gauge went down to Zero. Does this mean the alternator is bad? Or could it still mean a bad battery?
Dan
1988 Turbo S (Red)
Old 08-02-2006, 02:23 PM
Could be either one or it could be an a/c clutch drawing a huge amount of power. If you pulled the a/c fuse and the battery still drained, then that pretty much eliminates the a/c clutch. Next thing to try is see if the battery holds a charge. You can take it to the FLAP and they will charge it and test it for you. If it checks good, then put it back in and test the current draw. If the alternator is bad, I think a red light stays on while it's running. Since the alternator is more difficult to remove than the battery, check the battery first, then current drain, then alternator. That's how I would do it anyway.
Tom
Old 08-02-2006, 03:06 PM
To check currnet drain you put a voltmeter between the positive terminal and the positive cable and turn ignition to acc?
Dan
1988 Turbo S (Red)
Old 08-02-2006, 03:13 PM
check the belt for the alternator and the a/c. Did something happen to it when the R134 charge went in and allowed the a/c to kick on?
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 08-02-2006, 05:11 PM
Eldorado's Avatar
when you filled the a/c system, are you sure you didn't jiggle a wire on your alternator at all? I'd check the connections there.....
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 08-02-2006, 05:22 PM
Dont' think I juggled anywires. was nowhere near any.
Battery was dead so brought it to Autozone who charged it and tested it and said it was good. Brought battery home put it in car and drove back to Autozone for them to check the alternator. They said the alternator was putting out 11.0 volts and 25.6 amps. I made them check it again with the fuse to the a/c out and came up with the same values. Is this right? If not I need an alternator. If they are correct values what's next?
By the way the gauge in the car reads about 10 volts.
Dan
1988 Turbo S (Red)
Old 08-02-2006, 05:50 PM
Eldorado's Avatar
that seems mighty low...
your gague reads what your alt. is putting out..... 11 volts is not enough to charge the battery. time to get that thing replaced or repaired
Kyle
Old 08-02-2006, 06:04 PM
Will take it to a place by me that i got a starter for the car. I think they rebuild starters/alternators... How much of a pain is it to get out?
Dan
1988 Turbo S (Red)
Old 08-02-2006, 06:07 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Not _too_ bad. For a nice procedure see
www.clarks-garage.com
Sounds like an alternator or wiring problem to me. Check the alternator wiring. It runs from the alternator to the positive terminal of the starter motor. Make sure it is connected and isn't badly corroded at the ends. If the wiring checks out, then it's probably the alternator. That said it could simply be the voltage regulator, which is the first thing I would change before rebuilding the alternator.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 08-02-2006, 06:47 PM
Is the voltage regulator part of the alternator. Woudl a place the rebuilds alternators be able to rebuild the regulator also?
Dan
1988 Turbo S (Red)
Old 08-02-2006, 07:01 PM
