Unhappy Hit Problem replacing timing belt
I need a hint or two about how to pull the balance shaft belt pulley off the crankshaft.
I went to Schucks and got a gear puller, but the arms slip off the pulley before the pulley starts to move and the main bolt of the puller is buried between the fan shrouds.
Clark's Garage notes didn't say anything about needing a gear puller so I was wondering if there was another way of shifting the thing.
I'm also hoping that removing the pulley will let me see the bolts holding the sring tensioner.
This job is turning out to be a lot more painful than I expected. The first sign of trouble was the two threaded inserts spinning in the back cover instead of letting me unscrew the bolts.
Nigel
'87 924S 5sp
Slowly recovering from a warped head
Old 10-02-2006, 12:45 PM
One of the pulleys is the tensioner for the balance shaft belt. Its a 17mm nut on the pulley that loosens then you can take the belt of.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 10-02-2006, 12:53 PM
That Guy
Techno Duck's Avatar
I used a gear puller from Sears, its a two jaw. Stick a stocket ontop of the crankshaft bolt hole so you dont kill the threads. You may need a second set of hands to help you line it up..also you will amost defenetley need to take the radiator fans out (its easy, only 6 bolts..10 minutes to remove them).
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-02-2006, 01:21 PM
Tip #1 - remove fan housing. Three 10 mm bolts along top, and three along bottom. dicsonnect electricals, and remove from bottom.
Tip #2 - PB Blast. Spray PB Blast into shaft/gear in front, and behind gear, and tap on the shaft and then tap on the gear. The gear is probably stuck, (rust) on the key in the shaft. Re-apply PB Blast, and increase 'tap' to 'bang'.
good luck
JM
Old 10-02-2006, 01:23 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I have never needed a gear puller to get the balance shaft gear off. I usually spray the center with some WD-40 or other suitable rust remover the give the gear a few smacks with a small hammer, alternating sides (i.e. left, right, top, bottom, repeat) until you can see it wobble a little bit then it usually just pulls right off by hand.
Then I use a small prybar to get the cam belt drive gear moving and it will usually pull off by hand.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-02-2006, 02:00 PM
SoCal Driver's Avatar
If it's not leaking you don't need to remove anything.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-02-2006, 04:53 PM
