No start troubleshooting steps?
Had my grandfather call me and said that one of his other grandchildren's brother in law's 944 won't start.
I'm sure you can see my look of horror, as I try to troubleshoot *this* through the grapevine.
Here's what I know:
Won't STAY started. Will consistently start for 30seconds to a minute.
Replaced the speed sensor. I asked my grandfather if he gapped it to .8 mm, he said that honestly, probably not, I'll ask him.
What are the things I should tell them to check?
Obviously check for spark when it doesn't start, then what?
Thanks!
-Alex
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 12-07-2006, 07:36 AM
Greasy Member
many944s's Avatar
Since it starts and runs for a little bit, I would check your fuel supply/pressure. Could be something as simple as replacing a fuel filter.
Try swapping out the DME relay as well. If it has a bad connection, the current flow could make it warm up, then lose connection causing the fuel pressure to cease, and engine to stop.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 12-07-2006, 07:58 AM
Granite 944's Avatar
TPS, or bad AFS connector. LOOK at clarksgarage.com for more diagnostic help, and FOLLOW IT DIRECTLY. STEP by step.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 12-08-2006, 09:34 PM
Eldorado's Avatar
can they keep it alive by using the gas pedal?
if reving the enging keeps it running, it's most likely a vacuum leak.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 12-08-2006, 10:44 PM
Alex.
How'd ya come out with the diagnosis stuff? Good I hope!
Old 12-10-2006, 06:44 PM
