compression test results
so i'm still trouble shooting this slight miss that i have. i did another compression test again.
1- 180
2- 170
3- 174
4- 180
I know the closer the better, and i read that if theres a difference between 10% then it could indicate a leaky headgasket. does everybody agree these are decent #'s?
matt
85 (early) 944
78 sc targa
"The fool who wades in doubt will float like concrete"
Old 07-19-2007, 05:10 PM
winter-hater club member
nynor's Avatar
look good to me.
"COOL PRIUS!" - Nobody Ever
Old 07-19-2007, 05:18 PM
callmethewander's Avatar
Matt, how exactly do you do that test, prep and such?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 07-19-2007, 05:32 PM
Send a message via AIM to Icey1174
Good numbers
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 07-19-2007, 06:06 PM
Send a message via AIM to bholmes
Numbers look pretty good to me. Tonight I had a miss...turned out I forgot to put one of my plug wires back on after fixing a vacuum leak. DOH! can't always be that easy I know, but after the crap I have gone through for the last month getting things put together I think the good Lord knew I might snap big time if I had a legitimate miss LOL.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 07-19-2007, 07:53 PM
meister member
speedracing944's Avatar
Your within 10%
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 07-20-2007, 05:20 AM
get the engine up to running temp. pull the dme/fuel pump relay. connect guage to each cylinder and crank about 5x's, sometimes 1 or two more.
85 (early) 944
78 sc targa
Old 07-20-2007, 07:48 AM
fast924S's Avatar
Send a message via AIM to fast924S
Looks good to me, Have you checked wires and cap??? How about spark plug Gap???
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-20-2007, 02:17 PM
Also, hold the throtte open when you crank so it gets a full cylinder of air molecules! Otherwise the numbers will not be right...
Old 07-20-2007, 02:48 PM
