TNT25169's Avatar
Send a message via AIM to TNT25169
All Blocks the Same????
I can't find my PET cd and I was just curious, are the blocks for the 944 N/A the same as the Turbo blocks? If not, what is the difference?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 09-22-2007, 12:51 PM
winter-hater club member
nynor's Avatar
year for year, yes. with the obvious exceptions for increased displacement.
"COOL PRIUS!" - Nobody Ever
Old 09-22-2007, 12:54 PM
fast924S's Avatar
Send a message via AIM to fast924S
NO all blocks are NOT the same, If you look at a bare block they have different tolerance bores 0, 1 and 2. If you remove the head you will see the number stamped on the deck along with a stamp on each piston. SO you could get 2 blocks from a 87 944 and the pistons might not fit correctly if you swap them. Thats the only major difference I know of, Other then that same design
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-22-2007, 01:08 PM
TNT25169's Avatar
The only reason I'm asking is that I have 3 N/A motors and a customer looking for a turbo block to build a race motor. If it's the same block I can sell him one of mine.
www.apartabove.com
Old 09-22-2007, 01:17 PM
nynor's Avatar
that is interesting. what does that mean? my friend's 944 had two's stamped on his block.
Old 09-22-2007, 04:41 PM
fast924S's Avatar
That means he needs tollerance group 2 pistons
Old 09-22-2007, 04:48 PM
nynor's Avatar
i gathered that can you be a bit more specific?
Old 09-22-2007, 04:51 PM
fast924S's Avatar
OK,LOL I tried to see if there is anytmore threads on pelican about the groups but everythime I try and search my web browser crashes.
So anyway I dont know the measurements/specs for the groups, I know their is a 0,1,2, 0 being the tightest and 2 being the bigdest. Tol. group 2 will not fit in tol. group 0 or 1. 0 wont fit in 1 or 2 , ring gaps will be incorrect and so will piston clearances. So If the blocks marked 2 you need to find pistons that are also marked 2, unless your doing a aftermarket rebuild then you would give dia. measurments.
Here is a bad pic of my block marked 1
Here is the mark on the piston, again cell pic
Old 09-22-2007, 05:07 PM
fast924S's Avatar
Here is info from shop manual
Old 09-22-2007, 05:13 PM
TNT25169's Avatar
I learned something new today. But as far as bare blocks go, the turbo and N/A blocks are the same and using a N/A block to build a turbo motor with after market pistons and such won't cause any problems?
www.apartabove.com
Old 09-22-2007, 05:19 PM
nynor's Avatar
exactly.
Old 09-22-2007, 05:25 PM
