New Rotors - beginning to rust at the hubs
My new rotors are begining to rust at the hubs and vents - was I supposed to paint these areas before installing?
I've done brakes many times in my life but this is the first time I've ever had this problem and it may be that this is the only time I've noticed due to the phone dial wheel design.
So, what kind of paint should I be using for this area - or shoud I be powder coating?
Now that I've had the rotors on the car for 5 months, I suppose I will need to prep them - but how do I prep the areas where the wheel vents are?
They looked really good new but now they look really rusty...
Old 12-12-2007, 06:02 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
It's pretty common for any rotor or drum to get rust. They can be annodized to prevent it, but that always adds cost. I wouldn't worry about it though. I've done brakes on lots of cars and have never seen a rotor dor drum that wasn't rusty (unless it was brand spanking new)
Oh and you dont want to paint or powdercoat them either...pads wont like that at all.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-12-2007, 06:05 PM
That Guy
Techno Duck's Avatar
Only way to prevent it from happening is to paint the rotor hats. Use a high temp engine paint, available from almost every autostore. Hit them with a wirebrush to get the rust off, then wipe with acetone and spray.
The vents i usually never do. Painting the parts is mostly cosmetic and you dont really see the vented portion. What i have done in the past though was mask off the face of the wheel and lay it flat on a bench, then spray. If you get any overspray on the disc face, just wipe it off with acetone. Usually i am to lazy to mask off the face of the rotor as it takes a while..i just spray the entire disc basically and clean the face with acetone. Laziness prevails!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-12-2007, 06:08 PM
meister member
speedracing944's Avatar
I would just drive them.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-12-2007, 06:43 PM
Nobody Special
I've had zinc plated rotors on one of mine for 2 years. The only area with any sign of a rust bloom at all is the pad contact area and that's gone the first time you apply the brakes. Rotors can not be 'anodized', plated or coated only.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-13-2007, 04:15 AM
Thanks for the tips...fyi, I'm only talking about the "rotor hats" as I see thay are called - the surface area where the pads rest is not the issue.
Vern
Old 12-13-2007, 08:55 AM
idesign635's Avatar
Send a message via Yahoo to idesign635
I always paint the hats before I install new rotors.
94 968 Polar Silver/Black, LSD, 6 speed, Short Shift, Kenesis K58's, Adjustable Konis, M030 Swaybars, Dynatech Strut Brace, Design 1 Racing Lower Strut Bar, Air Box Mod, B&B Catback, RS Barn Chip, Big Reds
86 951 Black/Black Lindsey 3" Exhaust, Lindsey DP Wastegate, Lindsey Black Knob, 3 Bar FPR, MaxHP Chips
Old 12-13-2007, 09:12 AM
cycling has-been
bkreigsr's Avatar
Rust-olem hi-temp BBQ paint will work (brush on). Available from the local mega depot stores. 2 or 3 coats will last the life of the rotor.
Bill K
Old 12-13-2007, 09:27 AM
Dtchy's Avatar
Exactly what I did... Mask the rotor and paint the rotor hats black with high temp paint. Looks really good and prevents rusting. Don't worry about the vent holes.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 12-14-2007, 05:55 PM
Zinc plating is what I was thinking of. Thanks for correcting me.
86 Metallic Grey
Old 12-14-2007, 07:29 PM
Anodizing is an aluminum process, just so you know why you can't anodize the rotors.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 12-15-2007, 05:41 AM
sayporsha's Avatar
Porsche paints the hats with some kind of battleship gray paint.
Jeff
78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
Old 12-18-2007, 10:43 AM
Thanks for the tips. I'm going to paint the hats this weekend. I've got a newly powder coated set of phone dials coming out of the shop on Friday and I want everything to look perfect.
Here's what I started with:
Here's what it looks like 6 months later: (like crap) Lousy photo...it's raining
Old 12-18-2007, 01:13 PM
