problem when wet?
just some history about my car. every time i wash my car, then start it again to dirve it while im driving the car it gets really sluggish and it lags it feels like the first time learning stick the car jerks . today i washed my car as usual and it started up just fine and i moved it off my driveway, after sitting there for 20 min, i wanted to move it back on the driveway so i start it up after 5 secodnds the car just dies. I try starting it and it just cranks but nothing happens. I let the car sit for a while thinking maby somthing got wet and it needs to just dry out because i always have problems washing my car. So i try again about 3 hours later and it just cranks.
any ideas of whats going on here?
also before this my car was just sitting there for about 2 weeks and the battery died i jumped it and drove around and the battery still holds a charge. Not to sure if that well help but thats the latest update. i even tried starting it with the jumper cables on still didnt start.
944 fan
88' 944 n/a
Old 02-10-2008, 09:50 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Pull one of the spark plugs and put the plug cable back on it and lay it on the intake manifold. While cranking, make sure you have a good spark. If you have spark, then check for fuel on the fuel rail by loosening the nut on the end...if you have pressure, then we'll try something else.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-12-2008, 01:33 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
It actually sounds like your getting the distributor wet. Happens on lots of cars, not just these. I'm of the opinion to leave the car running while washing it instead of turning it off.
If you just let it sit a while does it start back up? I'm talking about an hour or so. If your in a winter area that could mean a day though.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 02-12-2008, 01:51 PM
Eldorado's Avatar
check your passenger side carpet... if you've got a hole in your battery tray, it could leak into the cabin and onto your DME.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 02-12-2008, 02:32 PM
It is possible that your plug wires arced and burnt your rotor.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-12-2008, 11:48 PM
Spray your plug wires with WD40 which will get you started - then REPLACE them with ORIGINAL quality.
Joel
87-944 Automatic 300,000 mi
83-944 5 speed 550,000 mi
Old 02-15-2008, 04:47 PM
