Trying to work for parts!
Send a message via Yahoo to hpservertech
Compression test
Can I do a compression test on the engine while it is out of the car or do i need to have it in the car so it can be cranked over?
Can I just turn the crank a few times by hand?
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 02-15-2008, 01:00 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Not sure turning it by hand would work but maybe. You could put an impact wrench on the crank bolt and turn it with that and it should work ok.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-15-2008, 01:19 PM
fast924S's Avatar
Send a message via AIM to fast924S
You could always bolt the bellhousing on and bolt the starter on and give it 12 volts. I Dont think turning by hand will work
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-15-2008, 02:18 PM
fastfredracing's Avatar
An impact wrench will not turn the motor, by the crank bolt, it will only snap it if you go clockwise, or loosen it . you need to either mount the bellhousing, and starter, of borrow/rent a leakdown tester, which is the better option .
Good luck
Fred
No left turn un stoned
Old 02-16-2008, 02:08 PM
