89 S2 struts
The front struts on my S2 are standard Sachs {i think!}
Question being do u have to replace the whole strut or do they have removeable inner dampers?
Thanks Mark
Old 03-02-2008, 04:02 PM
Makis's Avatar
You have to replace the whole strut. You can opt for Koni sport inserts but you will have to physically modify your struts. There is information on the WEB how you can do this and Koni expect you to do this way. This will be your best bet if you want to stay with standard setup and also cheaper then trying to get S2 Sachs unit that will cost more then 400 (200 pounds) each.
Old 03-02-2008, 04:51 PM
When u say modify do u mean specialidt machineing ,or just cutting and welding?
do u know where i can find the info on the net ?
Thanks again Mark
Old 03-03-2008, 09:42 AM
Here's my original post of the project with detail pictures:
Weekend Project Pics - Koni Inserts
It's actually not too dificult and took me about 5 hours. You'll need a spring compressor, hack saw, and basic tools. The Koni's came with directions but they are very difficult to understand (their translator could use some more english classes). The guys at 944online.com didsussed the entire project with me before I attempted to "cut" anything on my car.
Vern
Old 03-03-2008, 09:59 AM
Ok thanks just seen paragon parts website doing the conversion is $135 for the the pair?
cheap if it is!
Seems prety straight forward to do
Mark
Old 03-03-2008, 10:05 AM
That sounds too cheap. A good set of front struts should cost at least $100 ea. Maybe the $135 only includes the labor but not the actual cost of the strut insert? Better check to be sure.
Old 03-03-2008, 11:17 AM
Thats the price for the kit ,its a lot more if u want them to do the work
Old 03-03-2008, 03:15 PM
Makis's Avatar
You can source them in the UK near your home I think. Here is a link
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=KON8641-1414S&app=Y
But it works more then 135 $ each.
Old 03-03-2008, 03:21 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Here is the link for the actual struts:
http://www.*****************.com/product_p/koni-8641-1414s.htm
Here is the link if you want Paragon to actually do the work for you, Yes it's $135 for them to do it.
http://www.*****************.com/product_p/koni-8641-1414s-conversion.htm
Koni struts are way more then $100 each. For Paragon to do it there is also a core charge as well so you have to send yours back to them.
You are better off getting the inserts and doing the whole thing yourself. It's not that difficult to do and as said above it can be done in less then 5 hours with a saw & drill. You dont need a welder to do this. Very simple.
Here is the link to do it yourself:
http://www.tech-session.com/kb/index.php?article=36
I dont see the Koni insert for the late struts on Pelican's web site, not sure if they carry them.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 03-03-2008, 06:56 PM
Yeh ,but are the prices each or a pair ?
U will expect to pay more in the UK{ Demon Tweeks}
they dont call it ripp of britain for nothing !!!
If theres a big saveing to had buying from the US it may be worth buying from there
mark
Old 03-04-2008, 10:22 AM
Call or ask them. That's the best method to know for sure.
With the value of the dollar right now you might be better off buying them in the US then accross the pond. Should get more for your money.
86 Metallic Grey
Old 03-04-2008, 10:55 AM
