Angry Replacing Brake Pads fit problem ?
Man I am on a role of confusion with this car.
I have replaced many brake pads and this tops the list as the worst !
I have a 1990 944 S2 (without club sport) I bought the:
OEM Front Brake Pad Set, 944S2 1989-91, Without Club Sport Option, 944 Turbo 1986-88, Without Club Sport Option, 968 1991-95, Without Club Sport Option, Each
Brand: Mintex
And they will not fit this the slots between the medal hinges on the top and bottom...in addition I test fitted the caliper on the
Front Brake Rotor, 2 Per Car, 944 Turbo Without M758 Package 1987-89, 944S21989-91, 968 1992-95, Without Club Sport Option, Each
Brand: Zimmermann
And those little medal brakets on the bottom hit the rotors ??? Even with no pads installed...I am beginning to think I will need to file down the vibration damper on the back of the pad ??? I can't think of any other solution to get the pads installed ?
Old 03-20-2008, 01:22 PM
unindicted co-conspirator
looneybin's Avatar
I've heard of this problem, although i have not had it myself.
grind the tab down & it should fit
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 03-20-2008, 01:28 PM
Thanks,
Makes no sense really, the old brake pads look almost the same. I think this happens when the brakes have not been maintaned correctly.
Old 03-20-2008, 01:38 PM
