I'm looking for a whole new exhaust for my 87 944 N/A. I don't really need anything to fancy just wondering whats the best way to go about getting one.
Feelin' Solexy
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Custom User Title
My kid installed a Lindsey Racing 3" catless exhaust on his car (a 951). For the whole thing, (which connected at the down-pipe and included a Magnaflow muffler and tip) he paid $606.
It was relatively easy to install. And it sounds great. They have a 3" exhaust for the 944 NA that costs somewhat less, depending on what options you get. http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944EXHAUSTMILD
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Proprietoristicly Refined
The exhaust systems were stainless steel and hold up well. If you do not live in a "rust belt" state you might look into a used exhaust from a local yard to save shipping or look into an internet used supplier like:
http://dcauto.gotdns.com/section/index/3585451/202. Pelican also has a "classified parts for sale" forum. http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/ Good luck John_AZ 1988 924S + 1987 924S |
Go with The Pelican.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
If I get the one from LR do i have to get the MSDS headers, or does it come with stock? Also if i get it with a catalytic converter does it come prewelded so i wouldn't have to take it to a shop?
I'd check out automotion too. You can get a bursch headers and exhaust for a little over 600. downside is the cat is 500. I'm looking myself and will probably get the exhaust there, pick up a cheaper cat somewhere, and take it somewhere to get welded on. I've seen magnaflow cat's on ebay for around 60.
http://www.***************/
1983 944 This was probably posted from my phone, so please excuse any typos. |
My 944 scares adults
I was almost positive the exhaust systems on these cars were NOT stainless, the reason being my exhaust has a very small crack and to check if a local guy could weld it for me i held a magnet up underneath there...it stuck...not stainless steel.
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers 1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?) |
Super Moderator
uh, magnets stick to stainless steel. from http://www.azom.com/details.asp?ArticleID=1140
Stainless Steel - Magnetic Properties All stainless steels, with the exception of the austenitic group, are strongly attracted to a magnet. were you thinking of aluminum?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Misunderstood User
Still got the original on my 83. It is stainless and yes some grades of stainless do have a slight magnetic attraction.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Custom User Title
In comparison to the others, it's relatively inexpensive. And you'll likely see at least a little HP gain (mostly from ditching the cat). If you do get the cat, I'm assuming it would fit together like the rest of the LR pipes - they use compression fittings. But you might ask them to be sure. It was relatively easy to install. The only problems we had were that the hanger brackets were a little off. Fortunately, the hangers are adjustable (just loosen them and slide them forward or backwards on the torque tube). It ended up really great. Below - his stock exhaust and the new LR 3" side by side.
Redline Racer
They make 2 versions for the NA. One bolts up to a MSDS header and the other is clamped to the stock Y-pipe after cutting the cat off just downstream of the oxygen sensor.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
meister member
In the past I have bought a whole exhaust system from the manifold back from a fellow Pelican member for $60. I just posted a WTB add in the parts classified section.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
3" is serious overkill for an N/A.
When ever I get a chance, I plan to modify the stock cat-back section from my 951, and bolt it to the 944. It's around 2.5", and shouldn't be too much for the '83.
Jack 86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi 83 Porsche 944 - Still under re-construction. 08 Suzuki Boulevard M109R LE 02 Nissan Altima SE3.5 |
Will the MSDS headers fit ok on my car?
Redline Racer
I'd suggest finding a good used stock exhaust system, making a test pipe with a catalytic converter to swap in for passing emissions, mating it with some good headers (MSDS or Bursch), and splicing on a good sounding muffler.
I wouldn't want to go 3", since I've heard these engines don't do so well with a really big exhaust, unless maybe they are specificly set up and tuned to run well at high rpms with a nice open exhaust.
Higher grade stainless is non magnetic.
