| Registered Join Date: Apr 2008
				Turn signal
			Guys my turn signals just stopped working. I have check the fuse and relay and everything seems fine. The strange thing is that the hazards lights work fine. please help.  Joe | ||
|  06-16-2008, 04:46 PM |
| Registered |
			Maybe the switch is bad, since it would be a different switch than your hazards.  Break out the ol' multi-meter and see if you have continuity in that circuit.
				__________________ Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) | ||
|  06-16-2008, 05:42 PM |
| .... Join Date: Feb 2008
			when you turn it on does the light in the cluster stay solid? or does it blink?
				__________________ dolor et pavor Copyright | ||
|  06-16-2008, 05:56 PM |
				Turn Signal issue
			Guys I found out that its in the fuse board itself. When I lift it up and tilt it to the inside to look around the signals start working. So I have either a broken wire, loose connection or a bad fuse board.   man it seems to never end. | ||
|  06-16-2008, 06:14 PM |
