meister member
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
meister member
![]() ![]() ![]() ![]() Upon further inspection is appears as if the valve seat dropped out and fell into the combustion chamber. Speedy
Back from Beyond
So sorry for your loss, dude. I know how it feels to have this happen - my old Bronco dropped a valve and the damage was pretty much identical to what you're seeing. All the coolant got mixed in with the oil. It was the most disgusting fluid I've ever seen.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Cars & Coffee Killer
Wow.
I'm very sorry to hear this. I always thought of your 944 as particularly strong-running.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
oh, and Speedy, that sucks. At least you have an "interesting" failure to brag about. Most impressive.
1988 944... and a bunch of other cars
dear lord. I have to words for that sort of carnage. That's like.. top fuel dragster style engine failure.
M |
Used & Abused
I rely on my low fuel idiot light to tell me when to fill up, the gas gauge sinks to empty on anything less than 1/4 tank.
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
I am always sorry to see engine destruction like this and hope you fix it instead of bailing out. I would like to offer the following alternative theory:
#2 rod bearing spun causing the rod/piston length to increase, which caused the piston to strike the head breaking the piston above the top ring land and cracking the cylinder wall. The piston fragments are what bent the valve and caused the other damage. When you get it apart, let us know what you find.
Keith Belcher '87 951 nautic/cancan |
Writer/Teacher
HOLY GOD.
How did I miss this thread? Even more importantly, HOW DID YOU DO THAT TO YOUR CAR? I have been on Pelican for many years, and I have NEVER seen that kind of destruction to a 944 engine. To quote Ron Burgundy, "I'm not even mad. I'm impressed." Block is pretty much toast. Pistons are toast. HEAD is toast. Any idea what failed to cause such a meltdown?!? BTW, your engine bay is remarkably clean!
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
IMO, it looks like detonation to me... if you compare the color of the valves to the others that cylinder was running alot hotter or detonating before the blowup. Maybe a faulty injector???
Mark '86 944NA '10 VW Golf 2.5 5sp '99 BMW 540i Sport Wagon |
Sorry to hear about your loss. Amazing photos though.
'05 M3 - Alpine White '88 924S - Black '91 318IS - Alpine White '88 Honda Hawk '75 Honda CB360 |
vott does ziss do?
I have a complete motor if you need it
meister member
![]() Pulling the motor from the donor car. ![]() Motor pulled from donor car ![]() The donor motor in the garage. Today was engine pulling time on the donor car. I started at 11:00am and finished at 3:00pm. So it only took 4 hours to do. I did it outside with mosquitoes attacking me. Action plan... clean engine pull head and inspect cylinder walls and head renew head gasket, roller seals and such replace clutch pull my engine out of my '83 install new donor motor pray and turn the key Speedy
meister member
I think I will be alright unless if when I pull the head on the donor motor it's all chewed up. If so then we will talk ![]() Speedy
meister member
![]() What kind of long tube header is this? ![]() ![]() ![]() ![]() ![]()
meister member
What do you guys think about the couple of scratches on the cylinder walls?
The head gasket said "turbo" on it. Should I replace the head gasket with a "turbo" gasket? Speedy
meister member
Rich you are a madman. Here I'm thinking you'd need help taking the engine out and you've already taken 2 engines out. Your doing just fine without me and Joe getting in your way...good luck with your engine transplant.
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Proprietoristicly Refined
Speedy,
You are good. Donor engine out-head off. The gasket says turbo because it has been changed once before from the original OEM. The new gaskets sets all use the "updated turbo gasket" ![]() From the pictures, the scratches do not mean a thing. To begin to worry, you have to "catch" your fingernail on the scratch. Looks good. I know about the mosquitoes in WI. Previous Eagle River and West Bend. Again, I want some of the vitamins you're using. John_AZ Last edited by John_AZ; 06-27-2008 at 05:45 PM.. Reason: spelling and clarification |
BTW Rich,
Those are Bursch Headers
