So the calipers on my 92 968 Track wh0r3 could use some freshening up. They are in good working condition but take a good bit of heat and the paint is not looking so hot.
I have heard that there are places out there that will refurbish and repaint them and return them to me in pristine condition - but I cannot find them via Google. I have also read the threads on doing this myself - and it seems easy enough - but I would love to hear any new stories on the process if you would like to share. Thanks for all the great posts. I always find something worth reading when I am here. Tom R 92 968 GP White (with a new set of 996 17" wheels and Azenis HOORAY!) |
In the Fires of Hell.....
Tom, just do it yourself.
The key here is that the original calipers were anodized and then clearcoated, not painted black like a lot of people think. Get some aircraft stripper and a soft wire brush and get to work. I would take them off the car for this. Once you have them cleaned up, simply spray a few coats of high temperature clearcoat, and you are done. Keith Before: ![]() After:
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Misunderstood User
+1 for kd
Take the caliper off. diassemble Use break cleaner remove residue Good time to replace boot and seal Tape the sensitive areas Go to local PEP boys, etc and choose a color, red, black,silver. I like to use high temp clearcoat too. Reassemble Get a new spring clip set Remove the caliper plate from the hub Media blast to remove crud Paint the plate using the same caliper plate Reassemble Good time to check wheel bearings. Good time to check rotor Good time to replace brake line with ss
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
All I did was clean them with brake cleaner, sand them a little, and used some military grade black primer...stuff is bullet proof, sprayed them and put a high temp clear coat on them, then I took a 3M buffing pad and buffed the Porsche logo to a shine...the question is...do you have the later style 968 Brembo calipers that have the Porsche sticker on them ? I had to replace my front calipers and bought some 968 ones, they came with Porsche stickers
...thought they were knock offs at first ![]() ![]()
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
