Greasy Member
Picked up my dyno engine, looking for bits to start using it.
Well, I picked up the 44 engine yesterday that I will be using to dyno test the port matched cylinder heads I've been rebuilding. Down the line, I plan on lightly machining intake manifolds and throttle bodies as well to offer "matched sets". It looks like I may have another line on a partial engine to pick up in a couple of weeks, but am looking for some pieces-parts to fully assemble this dyno engine to start getting some numbers.
If anyone has a bellhousing or early wiring harness lying around, please fire me a PM with details on location and how much you would like for them. I don't need the sensor bracket or sensors, I already have a good pair. I have the DME all ready to go, and will be welding the test cradle up this afternoon. Thanks, Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
meister member
I may have a spare bellhousing. I might use the one from my '83 to put onto the 85.5 engine as the sensor area looks a little different and I will be running my '83 sensors and computer. I may also use my '83 flywheel on the 85.5 engine.
The bellhousing would be from the 85.5 engine. Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
meister member
Hey rstu964! Right back at ya!!!!
kigfuiqefheqifiuheuhceivcuqi rhefcfcfcfcfcfcfcfcfcfcfcfcfcfcfcufhcuncnwnuinhwue vfuuwfhurqheuhtgn erguhguhvuvhuhphuaevuhiavhvauhhvuhauvhaphpucvmerhu urihaehureh7uqrpgherqgahuirequhigreqpqhi9pg89puugh ieruprqi9fq89qehuerqu9greqregh[puhqge[pqe[piuerqguiogreqjklfflfdrueruerquiqrep;qquipepuiepeu uepuigghpuregphguhurererereieuhqergregereqghvruqig rhepvrvgeqhpruhhvievgqurhqghqevguqevgrhpguqe
Greasy Member
Speedy,
That should work. Tomorrow I will be cutting splines on a test shaft to go from the pressure plate to the dyno sensor. Not a whole lot of fun, but a nessesity with this style bell housing ![]() I picked up the engine from a guy that said he thought the t-belt had broken because the engine wouln't turn over, even by hand... When I opened it up, the head gasket was toast, but the break was from the oil passage! Cyl 1 had about 1/2 quart of oil in it, so the engine was hydro-locked. I still need to tear it the rest of the way down to blueprint everything, as I want to make sure I know every detail of this engine before I start putting it to the test! If everything goes well, I should have it re-built by the middle of next week. If I can track down a harness, I might start getting dyno info by the end of next week. -Nick
Trying to work for parts!
I have a bellhousing as well as a spare throttle body with tps. Let me know if you want them.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Greasy Member
I am currently checking to see if there is any difference between an early vs. late bellhousing. Is yours an early? I appreciate the offer for the TB with TPS, but already have several ready for testing. I will definitely keep that in mind though in the upcoming months as I start polishing TBs for different dyno runs.
Thanks, Nick
It's from a late 85. Just let me know.
meister member
I have both an early and a late bellhousing. IIRC the later bellhousing has an extra hole in the top for some other sort of sensor. I will check tonight to verify.
Speedy
Nick,
Sounds like you have your own engine dyno? Do you have any interest in testing an engine management system? I developed a fuel and ignition system. It is speed density, no air meter is required. I would expect some improvement in performance without the air meter restriction. It will need a Mopar 2.2 turbo hall effect distributor fitted to the cam end. The rest of the connections are plug-n-play. The other advantages are sequential injection, direct fire ignition, and real-time user adjustable parameters. If the unit demonstrates significant performance increases perhaps the project will be more than a hobby. Please note I am not selling units at this time. I have played with the system on air cooled VWs, Porsche 914's NA - Turbo, and a 2.2 Mopar Turbo with good results. My 944 is an auto, so testing with it and a wheel dyno might be fruitless. |
Greasy Member
Originally I was planning on using the engine dyno at the local Kmotion Racing shop as they owe me a few favors
However, now it looks like I have a line on a used DYNOmite setup! It comes with the hydro unit, all the sensors, the "magic black box" and software, I just have to supply the computer. Give me a month or so to get everything up and running. After that, I'm sure I could try your mods.I am hoping to get some stock baseline numbers by the end of this month. After that, I will be swapping the head to one that I have port matched and comparing the data. At that point, I would like to keep that head in place and start getting numbers from machined and polished intake manifolds, and eventually modified throttle bodies. I might get around to running a comparison between the stock air-box and the cone filter conversion, but at this point, it's low on the list ![]() -Nick
I have a couple of older PC's that run XP. I can donate to the cause. They are about 8 years old. What specs do you need? Do you need an ISA or PCI slot for the interface?
A month sounds good. Perhaps I can fabricate the distributor sensor mount and get things to run on my 944. |
Greasy Member
Thanks for the offer
![]() I used to be in the compu-biz, so I have a "few" boxes lying around!
