Removing cams big problem
I could only take 7 screws off from the cams,and the rest are striped,i did use the right tools the bolts r just too old and wont come out..i tryed drilling on two of them and using the extraction bit,it broke in there and i cant get it out nor can i drill again because its too hard... whats are my options,if i have to cut those cam holders in halfe then god damn it i will...and just get some used ones
Old 11-28-2008, 06:25 PM
thought of another idea,ill try grinding down the bolt as much as can with out getting close to anything else..then just buy what ever i damage used from some one..
Old 11-28-2008, 06:50 PM
Custom User Title
mikepellegrini's Avatar
We're talking the cam tower? If so, which bolts? The ones on the outside above the exhaust headders or the ones inside the tower?
If it's outside ones, they're relatively easy - you can weld a nut on the head of the bolt, or you can cut a slot in the bolt and take it off like a flat-head screw.
I saw a guy take one off that way - using a small dentist-style air powered drill with a grinder bit, he cut a slot in the top of the bolt, then used a crow-bar (the flat end) as a screwdriver and broke it loose.
I've also heard of guys pounding a cheap 12-point socket (slightly small) onto the bolt (so it jams on), then taking it off that way.
The bolts inside the cam tower are more problematic. I really am not sure what you could do there - without destroying anything. Pounding a socket on might work.
Make sure you "wake-up" any of those bolts before you attemt to break them loose. The steel bolt threads tend to bond with the aluminum after sitting for years.
From Clark's Manual:
http://www.clarks-garage.com/shop-manual/bolt-01.htm
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-28-2008, 07:57 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Worth mentioning, he has an S, so there is no cam tower since it is 16V
Took us 2 pages to sort that out in his other thread. Apparently he feels the need to start from scratch every time he encounters a new issue and not provide any real information.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-29-2008, 12:39 AM
Custom User Title
Hmm. I musta missed the other thread. Oh well...
16 Ford Expedition
Old 11-29-2008, 07:20 AM
