Recreational User
jerry920's Avatar
Where are those timing marks?
The one on the cam is easy, and it only makes one rotation per cycle, so it's either on or not. I am having more trouble locating the one on the crank. I think I have it, being wrong is too horrific to contemplate. Piston #1 is at top, checked through the spark plug hole, At the back of the engine, from the top looking down through the hole in the bell housing, I see 2 parallel lines.
Is this in the right position?
1992 BMW 850i
1984 Porsche 944 gone, but not forgotten
2007 Buell XB9SX
2005 Xterra
Old 12-31-2008, 05:22 PM
Nobody Special
There also is a mark on the flywheel that appears in the small TDC opening at the very bottom of the bellhousing that is easier to align than the one in the TDC window up top. Obviously that only helps if the car is jacked up high enough to see it. Sounds like your other marks are OK as long as you are looking at them square on and not from an angle.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-31-2008, 06:24 PM
Zero10's Avatar
Send a message via ICQ to Zero10
The flywheel will read "OT" and have a line beside it. As above, check for the groove on the bottom first. You can see significantly more of the flywheel from down here and can align it better. Once you have that groove lined up you will be able to see OT in the top window. Fine-tune it to match up with the protruding tab on the bellhousing and you are in business.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-31-2008, 10:50 PM
Schumi's Avatar
Most likely the flywheel will be rusty and the OT mark completely indistinguishable in the little window in the bellhousing on the top. When you know you are close, spray some brake clean or spray lubricant (anything wet really) on the flywheel and the marks will magically appear, then disappear when the liquid evaporates....
just ones of those tricks
M
Old 01-01-2009, 12:45 AM
Recreational User
jerry920's Avatar
Perfect Shumi! I though I had it, but the little spray trick brought it right out! Right on the mark.
Can't thank you guys enough for making a hair puller into an easy task.
1992 BMW 850i
2007 Buell XB9SX
2005 Xterra
Old 01-01-2009, 07:05 AM
