Broken Hatch Pin - How to Fix
While trying to adjust my rear hatch, I broke one of the rusty pins. The other one is pretty well stuck too so it will most likely break when I try to adjust. I did spray it with WD-40 a few days ago and let it sit, but here I am now.
Can I remove the bracket and drill out the pin? Or is it easier to get an entire new/used bracket and pin?
Thanks,
Rick
-Rick Central PA
1989 Linen Grey Metallic 944 Automatic (Daughter's first car)
1984 Slate Blue Metallic 911 Cabriolet ROW, 220 WHP, Steve Wong Chip, Fabspeed Muffler, Cat Bypass.
1987 Black 944S - SOLD 1969 Aubergine 911T - SOLD
Old 03-30-2009, 08:48 AM
Misunderstood User
Bracket easy to remove. Pins are replacable either steel of stainless available. I would try to drill it out. If the threads are bad in the bracket you will need to replace that too.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 03-30-2009, 10:05 AM
PRMN944
If you have drill handy, the auto parts store sell the drill sets to repair
the broken bolt without destroying the thread hole.
Old 03-30-2009, 11:29 AM
Professional Bull5hiter
Outback Porsche's Avatar
Be very careful. the bracket (wings) break easily. I ended up getting new brackets and pins.
Cheers
Jeff
83 944 Guards Red
23 718 GT Silver
Old 03-30-2009, 11:35 AM
Caponsacchi's Avatar
I just drilled out one of the mount bolts yesterday. The metal is very very easy to drill through. And yeah, watch those wings...
1987 Porsche 944
1988 Volvo 240
Old 03-30-2009, 12:09 PM
KLR KLR is offline
KLR's Avatar
The piece that the pin screws into is actually removable from the piece that bolts to the hatch. I doubt that you'll have much luck drilling out the pins (I didn't), but the female pieces are only about $10 each from Sunset. The pins are similarly inexpensive.
1987 951 - Stone Gray / Burgundy
15psi Guru Chips, Reliaboost, 3-bar FPR, KW Variant 3 Suspension, OE Euro Driving Lights, Iceshark Wiring Kit
Old 03-30-2009, 05:02 PM
elirentz's Avatar
^+1 Don't waste your time drilling it out. Just remove the block of rubber that the pin screws into and the old pin will pop right out.
05 STi
Old 03-31-2009, 04:10 AM
