Semper drive!
Jacking Points Clarified
Okay, I've seen the image that has been posted about on the correct places to raise my car from. Unfortunately, because of the small size of the image, it doesn't seem all that clear on the specific point to jack from. I'm mainly talking about the rear points, in front of the rear tires.
![]() I took the below image just a few minutes ago and wanted to clarify that the area marked in green was the proper location, and that the area with the red "X" was not. It may sound like a silly question, but I'd definitely rather be safe than sorry. ![]() ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten ![]() One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Semper drive!
Oh, one more question...
I've read that there seems to be 2 camps as to whether or not it is safe to jack the entire rear-end at once, using the transmission as a jacking point. Some fols do it all the time, and have done it that way for years. My own local Porsche mechanic and his crew lift from the case. The other side of this debate says that it is too much of a risk to damaging the tranny case that prevents them from using this method. My question here is simply, if one were to lift from the tranny case, using a hockey puck, or some other similar type of cushion, where is the best place on the case to lift from...directly between the axles, further back, etc...? Randy
Parrothead member
Ive always jacked mine right under the center of the case, between the axles Never had a problem
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Semper drive!
Thanks, Vinny!
![]() I'm working on doing a repair job on my blown cat and found I need more room underneath to really do the job right. I have the front tires up on ramps and wanted to lift the rear end up to place my SUV jack stands underneath the torsion bar end caps. Guess I'll look for a puck at WalMart on the way home from work toomorrow and will go from there. Cheers!
Custom User Title
I have jacked from the rear off the tranny and used the torsion bar tubes for jack stands. I typically jack from the center point on the sides.
Jacking points
Seems everybody has their own method. I thought about using the front ramps and torsion bar caps. I think my floor jack under the diff case between the axles will roll the car off the ramps because the jack does not lift straight up.
Any thoughts about this? Maybe the jack rolls on the floor? Last edited by jackrussell; 04-14-2009 at 09:26 PM.. Reason: Maybe I answered my own question. |
Semper drive!
Jack, I've also considered the idea that maybe the car would roll back off the ramps. Looking at it though, I really don't feel that will end up being the case.
First of all, the way the car is sitting on the ramps now, even with the parking brake off, it does not tend to roll to back side of the ramps. Also, there is a little, built-in, mini-chock on my ramps that the tire would have to roll up over before it started rolling down. Last, I planned to place my wheel chocks behind the back tires as I raised the rear-end, and adjust them accordingly, if needed, while lifitng the rear. I really don't think rolling backwards will be an issue here. I'll let you know! ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten ![]() One Marine's View Igitur qui desiderat pacem, praeparet bellum Last edited by rcecale; 04-15-2009 at 07:15 AM.. |
Parrothead member
I stick a chock behind the front tires on the ramps. I have a built in chock too, but still like an extra piece of security.
I always use the point marked with the red "X" in the second picture. It seems pretty sturdy, so I don't know why it would be a problem.
Semper drive!
Okay, here's it goes...
Front tires up on ramps, moved as far forward as I could. Jack underneath the transmission. chocks behind the rear tires, parking brake released. Up she goes, real slow, just in case. No "noticeable" movement...or so I thought. Front tires had worked themselves toward the back of the ramp platform, resting on the mini-chocks (bumps) at the rear of the platform. It seems the car moved backward about 1.5 inches or so. Okay, not a problem, jack goes underneath the front crossmember. Raise the front just enought to ease them off the ramps. A few taps on the ramps, pushing them toward the rear of the car. Front tires are now posotioned toward the front of the ramps again, and the jack is lowered. Looks pretty secure to me! ![]() ![]() Randy
Thread Tools | |
Rate This Thread | |
