weird steering problem
I had the 44' on jack stands today to bleed brakes, and get the clutch bled right. Since i had her up on the stands i started to mess around with the steering wheel to see where a squeek was coming from. needless to say i was pretty shocked to see that when i turned the wheel the drivers side strut tower washer/bolt thing would move with steering wheel, almost a perfect 1:1!!
![]() I really don't see it being anything that bad, as i mostly drive her a few miles work. What do you guys think it could be?
dolor et pavor Copyright |
Semper drive!
Both of mine do that, exactly the way you described it. (1:1) Discovered that while I had the front end up in the air bleeding the power steering system.
Was shocked initially, as you were, but assumed that was normal, since both sides were turning like that. I sure hope it's normal!!! " ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten ![]() One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Shouldn't the whole strut assembly turn when you turn the wheel?
That's how it was on my GTi, anyway... C.
Charlie '99 996 C2 6 speed - Arctic Silver |
That's perfectly normal--strut suspensions typically use the upper mount as the rotation point for the steering.
Rod Schneider Ball Ground, GA 88 928S4, 87 Corvette, 88 Fiero GT, 16 Mustang EcoBoost |
Thread Tools | |
Rate This Thread | |
