Weird noise when shifting into 2 or 4
'86 944 150k unknown clutch life
Within the last 4 months, when I shift from any gear to 2nd or 4th, I sometimes hear a hollow sounding clunk - almost like I banged a wrench on the torque tube or something.
Doesn't happen all the time, and if I'm real easy - not at all.
Going into or coming out of any or the gears is smooth as butter, it's just that noise is bugging me.
When I got the car the shifter rattled like crazy, so I replaced the pin on the shifter and used a spring washer to take up any remaining slack. That's worked great, but recently it started vibrating again. My fix seems to still be tight, so I suspected pieces down the line. I crawled underneath and felt the levers and all seemed to be OK. I ended up stuffing some foam in between the shift rod and the torque tube and the vibrating stopped.
Any ideas?
'99 996 Arctic silver over black. In the past I've owned and wrenched on a '96 Audi A4, '86 944 NA. '79 928, '72 914. Non-Teutonic vehicles of interest: 3 MGB's (one converted to V8 power), Triumph Stag & TR250, Jensen-Healey, T-Bird SC. Most recent "project" was a Factory Five MKII Roadster.
Old 04-07-2010, 11:53 AM
Proprietoristicly Refined
John_AZ's Avatar
Originally Posted by steveu812 View Post
'86 944 150k unknown clutch life.
Any ideas?
An easy check on the clutch disc is in Clarks.
Stick a deep well socket that just fits between the bell housing and fork. Then measure the socket.
Checking Clutch Disc Wear
If by "unknown" you mean you do not know if you have a rubber or spring clutch disc, disconnect the battery, remove the starter, poke your finger deep into the bell housing feeling for small bits of rubber. If tiny bits are found, be really gentle on the clutch until you do the clutch job.
The clunk could be a burned out clutch pilot bearing that the drive shaft fits into on the flywheel.
Or it could be a cracked TO-throw out bearing "guide tube".
Only if you find out about the "unknown" can you be sure.
GL
John_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-08-2010, 07:28 AM
bad rubber center.
Good luck, George Beuselinck
Old 04-08-2010, 08:04 AM
John_AZ's Avatar
George is correct.
It is a rubber center clutch with the "Make It Home Tabs clicking
Old 04-08-2010, 11:14 AM
Toofah King Bad
Rasta Monsta's Avatar
What a great pic. . .looks like those tabs have been pounded a bit, eh?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-08-2010, 11:34 AM
