968 caster block upgrade
I have looked over my suspension and would like to upgrade the control arm inner rear mount. Does anyone know if the 968 upgrade (951.341.023.01 M260)fits series 1 cars? TIA
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Pretty sure an aftermarket company makes a Delrin or PU version for the early cars that will be cheaper..
dude |
Toofah King Bad
Methinks the 968 units are for Al arms only. You might consider Prothane poly bushings. . .$25 will refresh all bushings on both sides (after you enjoy the heck out of removing the factory rear).
rasta P.S. You are looking for Prothane Rabbit/Golf Mark I
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I'm doing the prothane bushings Rasta, just wanted to clean up the mushy rubber bushing in the control arm inner rear mount. What about Fastech? Anyone know about them?
Toofah King Bad
Hmm, not following. The Prothane set comes with a poly bushing for the rear "castor" mount.
What do I use at the front of the control arm?
