Same bolt pattern?
I own a porsche 944 turbo and was wondering what other cars use the same bolt pattern? I'd rather not pay for a set of custom wheels. Are there adapters that work well if no other wheels will fit?
the bolt pattern is 5x130. which is only used by porsche. all porsche's are this pattern. so 928, 911, boxster wheels will all fit....if the offset is correct.
There is usually someone on ebay selling wheel adapters that allow you to use Chevy wheels. I have no idea what quality they are or how well they work.
Robert Currently Porsche less (but the wife has 2) |
Toofah King Bad
What year is your turbo? You might want to look at Porsche Wheels, Tires and Accessories, they have a big selection of used factory wheels.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I have a set of adaptors I'd sell, which will convert 5x130 to 5x112 which is used by Mercedes-Benz and the 5-lug Audi and VW and possibly other vehicles.
What year is your 951?
- Elliott Grafton - 944Barn |
I was wondering mainly what rims I can throw right on without adapters at all. What other porsche rims will fit without offset adapters? I've heard 933's might work but I'm not exactly interested in messing with adapters to be upfront.
rims
I bought my rims at tirerack.com and was very pleased with the service and product
![]() ![]() 1970 -914 / 1982 -911 1984 -928 / 1987 -928 |
All Spooled Up
All porsche since 83 use 5x130. There only 2 other models from other mans that go 5x130. One is a mercedes model, other I forget, but think both might be SUV.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
All Spooled Up
Other may be VW - not 100% sure. That would make it a straight-up, german only game.
Garage Helper
Nothing wrong with using adapters/spacers under 2" depth. Even over the 2" depth they are safe to use but now one has to consider wheel bearing life. The further off center the center of the rim is from the center of the pair of wheel bearings the shorter the bearing life. Most Porsche hubs are spacers used to correct wheel offset and bearing center.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Thread Tools | |
Rate This Thread | |
