When I have to rebuild the engine...
...because my crankshaft has play, what are my options, costs included please, for a '91 944 S2 Cabriolet? Thanks much!
Old 07-01-2010, 06:54 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
What do you know or what have you measured to know why the crankshaft has play? Have you miked out the block and crank and inspected the bearings? It could be you may need a complete motor or as simple as new bearings and a rebuild - hard to tell with the skimpy info here.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 07-01-2010, 07:19 PM
I just spent the winter resolving the same issue on the engine of my 1989 S2, thrust bearing was worn on the front side. I found out I had an issue because under heavy braking the clutch pedal would get soft.
Quickest option would be to buy a used engine, I've seen prices all over the place lately from $2000-$4000 depending on mileage. If you have a shop pull and rebuild the engine I'd think it would cost a minimum of $5000 for a full rebuild, probably more like $7000-$8500 at a reputable Porsche shop. I pulled my engine last November and spent this spring rebuilding in in my garage with some work being done by machine shops. I haven't totaled all my invoices up but I figure I spend somewhere around $2500
Old 07-01-2010, 07:57 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
That sounds about right. Thats about what I plan I spending on my rebuild.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 07-01-2010, 09:19 PM
Back from Beyond
You know, it's too bad we can't spin in new thrust bearings with the engine in the car...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-02-2010, 11:37 AM
ernie9944's Avatar
This is what you need for sale on RL asking $4,ooo.oo.Been done with sucess a number of time.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 07-02-2010, 12:23 PM
porschetub's Avatar
Top marks Krazykarl on the DIY comment,if you have the knowledge to do it yourself you can save alot of money,best to take your time check and double check along the way,label and bag clean parts and use the resources on this site.
You will need to check the thrust faces on the crank for wear ,once the white metal has gone its a hard face wearing on a hard face.
IMO the Porsche dealer overhaul is a money pit (you pay) as many parts are changed because the "book says" and not based on the real condition of the motor,you pay to cover them!!.
Old 07-08-2010, 10:07 PM
Tags
944 engine overhaul
