3D914's Avatar
Speed,Reference, & Timing Sensor
I cannot find any reference in the Haynes manual, nor on this forum about the third sensor that connects to the sensor bracket. From the parts catalog, it appears to be a timing mark sender - is this correct?
Secondly - is there any adjustment for this sender/sensor?
Picture is from Clark's Garage - modified to indicate timing mark sensor.
TIA,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 07-24-2010, 04:23 PM
yarfk
kfray's Avatar
This sensor is only used by the Porsche dealer mechanic connects to Porsche test equipment.
If you follow the lead you will find a connector mounted to a bracket at the back of the camshaft housing. This connector is not connected to anything. I removed this sensor and blocked the hole.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 07-24-2010, 05:21 PM
