"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Angry Wow
cant even find the tool for cv bolts the 12point double torx or cheeshead sears, and autozone doesn not have em and think im nuts
Old 09-23-2010, 10:40 AM
....autozone does have em. maybe they're out of stock.
try pepboys, oreilly's, napa
Old 09-23-2010, 10:54 AM
In the Fires of Hell.....
kdjones2000's Avatar
It is called "Cheesehead" or more commonly "12 point internal".
Pep Boys carries them in stock. Checker's/Oreilly's doesn't, not sure about AZ.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-23-2010, 11:13 AM
Porch's Avatar
Autozone does have them, but nobody there will probably know what you're talking about. In the tools section they have a separate 4' section that's called "OEM Tools" or something like that. They're all in red and black boxes. In there, they have a pack of 4 cheeseheads, all the sizes you'll need.
~Chris
1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear
1993 Jeep Cherokee - 3" Lift, 30" tires
Old 09-23-2010, 11:19 AM
smokin_944's Avatar
They are also called triple square. Available at every good tool place around.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 09-23-2010, 11:30 AM
mayPOR944's Avatar
i had to go to Napa only place that had them
Old 09-23-2010, 06:47 PM
kwikt 911's Avatar
Spend a little more from Snap on or Mac tools. It's worth it for these especially.
Old 09-24-2010, 06:12 AM
rickharrison's Avatar
+1 Same here....Snap-on baby!
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 09-24-2010, 06:37 AM
The newest of the noobs!
grendiers's Avatar
Us 924/944ers can't afford Snap-on tools! THey have triple square tools under the Performance brand at Oreilly's. An affordable $5.45 pack, now pass the beer nuts!
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 09-24-2010, 06:51 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
replace those cheeseheads with the regular 6 point the 911 uses.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 09-24-2010, 07:01 AM
This.... The chodes at autozone told us they didn't have them... and were like HUH, when dad found them...
Old 09-24-2010, 07:19 AM
Shops that sell VW parts usually have them. I think I've seen them at Sears, also.
Old 09-24-2010, 11:27 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
I don't think we stock them anymore. And our tools are okay, but for this type of thing, I wouldn't buy them unless you're only using them now and then.
Keep your receipts, anyways, because most of the tools are lifetime warrantied.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 09-24-2010, 05:11 PM
Until the cheapos strip the head, then you'll wish you passed on the beer nuts and bought decent tools instead!!!!!!!!!! Try using a cheapo on the cam sprocket and see how comfortable you are with you decision. You don't need snapon, but get a quality set made of quality hardened steel. JMO
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 09-24-2010, 09:26 PM
banana944's Avatar
http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=JT-XZN1008PC&CTMP=1 Got them through my work, Advance Auto Parts, and they are good quality, strong, and not the cheap ones you have to put in a socket.
ZDMAK also has alot of Porsche specialty tools.
Old 09-27-2010, 08:26 AM
Non Compos Mentis
I bought the tool right here from Pelican.
Old 09-27-2010, 08:33 AM
KEV951's Avatar
go back to autozone, or pep boys, or napa, THE CORRECT TERM FOR THIS BIT IN THE INDUSTRY IS CALLED TRIPLE SQUARE, not cheeshead or 12 pt internal torx, so what is it?
TRIPLE SQUARE
Old 09-27-2010, 09:21 AM
