"THERE IS NO SUBSTITUTE"
cant even find the tool for cv bolts the 12point double torx or cheeshead sears, and autozone doesn not have em and think im nuts
....autozone does have em. maybe they're out of stock.
try pepboys, oreilly's, napa |
In the Fires of Hell.....
It is called "Cheesehead" or more commonly "12 point internal".
Pep Boys carries them in stock. Checker's/Oreilly's doesn't, not sure about AZ.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Autozone does have them, but nobody there will probably know what you're talking about. In the tools section they have a separate 4' section that's called "OEM Tools" or something like that. They're all in red and black boxes. In there, they have a pack of 4 cheeseheads, all the sizes you'll need.
~Chris 1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear 1993 Jeep Cherokee - 3" Lift, 30" tires |
They are also called triple square. Available at every good tool place around.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
i had to go to Napa only place that had them
Spend a little more from Snap on or Mac tools. It's worth it for these especially.
+1 Same here....Snap-on baby!
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
The newest of the noobs!
Us 924/944ers can't afford Snap-on tools! THey have triple square tools under the Performance brand at Oreilly's. An affordable $5.45 pack, now pass the beer nuts!
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
Location: In a dumpster behind Albertson's in Los Angeles County
replace those cheeseheads with the regular 6 point the 911 uses.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Shops that sell VW parts usually have them. I think I've seen them at Sears, also.
Coming up on your left...
I don't think we stock them anymore. And our tools are okay, but for this type of thing, I wouldn't buy them unless you're only using them now and then.
Keep your receipts, anyways, because most of the tools are lifetime warrantied.
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
__________________ Until the cheapos strip the head, then you'll wish you passed on the beer nuts and bought decent tools instead!!!!!!!!!! Try using a cheapo on the cam sprocket and see how comfortable you are with you decision. You don't need snapon, but get a quality set made of quality hardened steel. JMO
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=JT-XZN1008PC&CTMP=1 Got them through my work, Advance Auto Parts, and they are good quality, strong, and not the cheap ones you have to put in a socket.
ZDMAK also has alot of Porsche specialty tools. |
Non Compos Mentis
I bought the tool right here from Pelican.
go back to autozone, or pep boys, or napa, THE CORRECT TERM FOR THIS BIT IN THE INDUSTRY IS CALLED TRIPLE SQUARE, not cheeshead or 12 pt internal torx, so what is it?
TRIPLE SQUARE |
