"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Porsche Crest How to replace odemeter gears????
were are they located how long to replace how do you replace them and wear do you get the gear.
Old 10-07-2010, 05:38 PM
luckily you have a later dash.
There is a good write up on clarks-garage
Clark's Garage Home Page
just go to the "Garage shop manual" then to "odometer repair"
Jackson
Old 10-07-2010, 06:14 PM
Also, for a good, detailed right up, with pictures, check out Rennbay.com. They have a tutorial on odometer gear changes. Their write up is on a 928, but once you get the gauge cluster out, everything is the same. I did this last month, and the whole process only took about an hour.
Old 10-07-2010, 07:04 PM
For pictures check this thread from last year:
Dismantling a Gauge cluster
There is also another link at the end of that thread to more information on this site regarding odo/speedo gears.
Searching odometer gears here will also find you many other threads w/o pics if you don't find what you need in the above threads.
88 944 na
07 335i
12 Cayman
Old 10-07-2010, 08:15 PM
