Did I buy the wrong flasher relay?
I thought I purchased the correct replacement part but now it doesn't look like it.
1984 944
Car was purchased without a flasher relay installed so I have no original to refer to. I purchased a 191 953 227 A since that is the part number.
The part arrived
However, it's a three pin relay and my relay box has female for four pins. The relay physically will fit so maybe that extra pin was just for placement? Seems weird to me though because the numbers for the pins on the relay holder do not match those on the relay itself.
Old 10-30-2010, 07:58 PM
ernie9944's Avatar
1984 944
The part arrived
For your 944___ Pelican New parts Catalog is giving number(1H0-953-227-M5206) for a flasher -turn signal relay & it's a three pins,are you sure you're trying to fit that relay in the rigth place, number (X1) is the location where it goes on an early 944.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-30-2010, 09:15 PM
Yes, that's the spot X1. I did order the correct relay according to the manual. But apparantly the manual isn't correct.
I ran across another thread where someone ran into the same thing. I now ordered 914-618-303-11-M504. Appears to be the four pin that I need.
Old 10-31-2010, 06:18 AM
All Spooled Up
Did you try the 3-pinner? It MIGHT work, and would not cause any damage if it did not. It simply would not activate.
Oh, and that's XI (roman for 11), not X1.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-31-2010, 06:25 AM
I didn't try it. I was wondering if it would cause damage or not.
Best I can tell the extra PIN is just to activate the "pilot light" which I assume is the dash light.
Think it's safe?
Old 10-31-2010, 06:53 AM
All Spooled Up
Bosch relays (and most automotive relays, in general, follow the bosch pinout scheme) are all based on the same pinout, with the 3-pin being the most basic.
I just went out and checked my 951, and the signal relay IS 3-pin, but the socket DOES have 4 slots. The signals, flashers, and indicator light all work fine.
Old 10-31-2010, 07:15 AM
Great, thanks a bunch!! Really, thank you.
I will go try it. Argh. I might have ordered another part I don't need.
Old 10-31-2010, 07:27 AM
Worked perfectly. Thanks again!
Old 10-31-2010, 05:21 PM
All Spooled Up
No problem.
Old 10-31-2010, 08:40 PM
M. Murphy's Avatar
I have a 83 NA that the turn signals and flasher work but cannot switch on high beams. Could this be the relay for me? Have to wait til spring to try it though my 944 is in the Carjacket.
Mike
Old 11-05-2010, 08:05 AM
All Spooled Up
Most likely the stalk switch.
Edit: Unless you were the victim of the un-likey event of both HB filaments burning out at the same time
Old 11-05-2010, 08:12 AM
M. Murphy's Avatar
Thanks Wild Man. No, both high beams function. When the stalk is pulled back there is no click to the high beams just the momentary on of the high beams.
Old 11-05-2010, 05:46 PM
Redline Racer
HondaDustR's Avatar
Do the regular headlights work? It may be your headlight switch, fuses, or some wiring problem with the main switch in addition to the stalk switch. There are no headlight relays (unfortunately). The stalk switch will divert voltage directly to the high beams when pulled for flashing, but rediverts the voltage passage back to through the main switch when you click it to high beam mode. It could be the stalk switch, but the main switch could also be a problem. I know because when my headlight switch eventually melted down (why aren't there relays again?), the only lights I had were the high beams only if I held the stalk in.
If there's no click to activate high beams, the stalk switch itself is most likely broken.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-05-2010, 09:09 PM
M. Murphy's Avatar
I think you are probably right about the stalk switch. The previous owner had apparently gotten frustrated with it because the stalk switch notch was pulled right out of the little divet.
Other than that the lights work normal (somewhat dim). You are right, why no relays. I normally have a lot of respect for Porsche engineers but this car in some respects seems to have been built by fired GM bean counters.
Old 11-06-2010, 01:51 PM
Redline Racer
HondaDustR's Avatar
Yeah, I went from a 1.9v drop to a 0.15v drop between the battery and the headlights when I made a relay harness for them. The lights are alot brighter and actually useful when it's dark. Good upgrade to make.
Old 11-06-2010, 03:00 PM
