Rogue Tuning
Rogue_Ant's Avatar
Well the bluetooth module still has to go through USB. And USB communication is pretty robust, with very low bit error rate (something like 1 x 10^-10).
I wouldn't worry about using a bluetooth module.
-Joshua
www.RogueTuning.com
Old 11-16-2010, 07:55 PM
flash968's Avatar
USB is not the weak link - knowing the dropout rates of bluetooth, the idea of that signal with all that critical data being transmitted wirelessly does not instill confidence - why wouldn't you just plug the thing into the computer? it's not like it could be more than 3 feet away anyway for tuning
i've spent about 200 hours tuning a kit this year, and the part throttle stuff is hard enough to repeat consistently without adding bluetooth error rates and drop outs to the equation - that just sounds like a bad idea to me, and no advantage that i can see to it
Old 11-16-2010, 09:14 PM
Rogue Tuning
Rogue_Ant's Avatar
Even if bluetooth is the weak link - the signal still has to go through the USB error detection. So if there is a bluetooth dropout or bad bit, the USB should detect it and request the packet to be resent...
Eh - different strokes for different folks.
-Joshua
www.RogueTuning.com
Old 11-16-2010, 09:19 PM
All Spooled Up
In 2 words: wireless connectivity. There are wires all over the place in my house, and I am trying to prevent that from also being the case in my car.
But now that I failed to obtain a module from motes, I'll have to use one of my own. The ones I have conform to the bluetooth 2.0 spec, and I would think that the pinout (V,D-,D+,G), which is standard USB, would match the header side of the ostrich that has the 4 pins in a row. Can anyone confirm this?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-17-2010, 05:34 AM
