using ATF in 944 trans with factory LSD
I have a 1983 ,944 with manual trans and factory LSD
can I use auto trans fluid in this gearbox for race application?
Old 01-17-2011, 09:49 AM
ernie9944's Avatar
NO____never heard of anybody using auto trans fluid in a 944 it will be suicide.Use only gear oil syntec either 80w90 or 75w90.The brand will be whatever you fancy, most owner will use (Red line -Swepco-Mobil ect )I will stay away from Royal Purple. And make sure it's compatible with your LSD.Some boys out there with racing experience will probably come on & guide you in.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-17-2011, 10:21 AM
commdiver's Avatar
Swepco or Red-line 75w-90 should be used for great shift and extra protection!
I think you heard somewhere that ATF is used as an old manual transaxle and transmission cleaner fluid. You can warm up transaxle then drain transaxle fluid oil and then slightly overfill with ATF. Then rdive car gently on road for a few miles around town ONLY?
Then drain the ATF, as it has a huge amount of cleaning properties. Then you can re-fill with fresh gear oil!
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 01-17-2011, 12:41 PM
Used & Abused
Ever heard of GM synchromesh fluid? It's not a standard gear oil and I can't vouch for it though it is compatible with the metal types in your transmission.
A friend of mine uses it in his turbo grand prix transmission and he's always raving about the stuff. I did look it up and seen it was being tried out in many different transmissions. Most with positive outcomes.
Pennzoil sells their own brand of the same stuff.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 01-17-2011, 05:49 PM
I believe you're only supposed to use GL4 with the LSD. Not the more common (and modern) GL5.
Old 01-17-2011, 06:50 PM
RedBaron's Avatar
Use a GL4 rated fluid. I use Redline MT90 in my S2 box with LSD and it is fine.
Do not use swepco, as it is a GL5 fluid.
Old 01-17-2011, 06:59 PM
Doesn't GL-5 cover GL-4 requirements?
Old 01-18-2011, 06:02 PM
Used & Abused
no, the formulation for gl-5 has properties that are harmful to your transmission.
Old 01-18-2011, 07:21 PM
Use a GL-4 lube like Redline MT-90 or Amsoil MTG...GL-5 is really not ideal and may cause some synchro issues long term...Both Redline and Amsoil are easily obtainable and do make a difference in the shifting feel.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 01-19-2011, 05:47 AM
Redline Racer
HondaDustR's Avatar
While GL5 tends to be more agressive on brass syncros, it also generally offers more protection for the diff and final drive with its increased EP additives. It gets tricky that way since the box is a transaxle. Its your choice, and the red line/amsoil is good stuff. I use the Mobil1 Synthetic 75W-90 and have had good results. I like to drive it hard, but I also match all my shifts and rarely make the syncros work.
Here's a very good link to a gear lube lab study. Unfortunately, it does not include any GL4 spec lubes.
Royal Purple not so good? Gear Lube Study
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-21-2011, 07:35 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Use AMSOIL MTG, "Wow" ...
Roadsportusa;
LoL, to Oliver 88 recommendations.
I use AMSOIL MTG in my S and it made a " World of a difference".
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 01-21-2011, 05:20 PM
guru944's Avatar
Thumbs up Try, AMSOIL SVG75w-90 for Diff LSD.
Opps!
This AMSOIL SEVERE GEAR is for your diff as well.
also use this in my S, Just love AMSOIL Products...
Later...
Guru944
Old 01-21-2011, 05:24 PM
Where do people hear these things....ATF is a hydraulic fluid with some lubricating properties. Can you imagine ATF in a manual tranny at race speeds....holy s...............!
Old 01-25-2011, 10:15 AM
Redline Racer
HondaDustR's Avatar
ATF is more or less 10 or 20 weight mineral oil with alot of detergents, anti-foaming, and other sorts of additives that make it also a good hydraulic fluid. Alot of other hydraulic fluids likely also are mineral based. It is too thin to protect under the loads encountered in a differential/final drive and lacks the EP additives, but there are "hydraulic fluids" that do. Alot of farm tractors run a common sump between the hydraulic systems and the gear case, including the final drive and differentials and require a whole lot of just one oil. The point is, it's all oil at the end of the day, just a matter of using what has been properly formulated for your given application.
Oh, and 80 weight gear oil sounds pretty thick, but it really isn't much thicker than 50 weight motor oil at operating temps. Just a random fact of the day.
Viscosity Charts
I second ATF as a fill for flushing the tranny out. Just drive it gently to get it warmed up.
Old 01-25-2011, 01:56 PM
As with grades of oil for specific application its all in the design. The 944 manual trannies were not designed and tolerences for ATF's.
As for racing I would be more concerned about potential relibility issues it might present than what potential " miniscule" gains I might get from using a different oil.
Racing is 40% chassis set-up 20% driver, 20% engine and 20% pure luck. Reducing friction by .01% in the tranny is just not going to be your winning water shed.
And any thought of it in a street car is simply wrong.
Old 01-26-2011, 05:57 AM
smokin_944's Avatar
Amsoil, the good stuff
I agree. I personally use Amsoil synthetic 75W90 and it is so far the best I've used. However, I have only driven 80,000 miles with the car so my experience is limited.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 01-27-2011, 08:19 AM
Pete R's Avatar
Originally Posted by guru944 View Post
Roadsportusa;
Later...
What part? He's spot on. The problem is 944's and 928's have the tranny and diff sharing the same fluid. Gl-5 would be ideal for the diff but they are TOO SLIPPERY for the syncos to work well.
I have used both redline and Amsoil both are excellent and one offers no benefit over the other. and there are many others that will be adequate. I used to use a standard oil in my 928 and had cold shifting issues.. swithed to the Redline and I no longer had them.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 01-27-2011, 09:42 AM
sasquatch's Avatar
Many new cars run ATF as a manual transmission fluid. My Mercedes Benz uses ATF in the transfer case as did my old 1989 full sized Bronco. We ran ATF in 2 stroke MX bike transmissions for years without a problem (KTM and Husqvarna).
I do not suggest it in the 944, but just wanted to say that other brands actually spec it.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 01-27-2011, 12:25 PM
Back from Beyond
I'm with the Amsoil guys on this one. Anything else would be like asking your car to drink vodka instead of schnapps...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 01-27-2011, 01:51 PM
