All Spooled Up
I like that response so much that, in addition to going +1 on it, I'm not even going to bother to read the rest of the posts in the thread.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Just thinking out loud
You seal it up with gaskets and o-rings. They have seal kits that are available. They're not very expensive either, maybe the cost of a couple of cans of 134a. Refrigerant isn't getting any cheaper.
83 944 91 FJ80 84 Ram Charger (now gone) |
I saw a new compressor listed for 275 somewhere on line. I don't need one so I didn't pay attention to who had it. They are not too bad to swap.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
The parts you need are K20-2005 and K20-3115. Any a/c shop should recognize Santech part numbers, if they don't, run fast.
uvachief
Matt, when I finally get the 86 944 NA out of hock off the engine rebuild, I plan to send you a decent compressor over the holidays and let you have a whack at rebuilding it with better Santech seals.
Sincerely, uvachief ![]() 1986 944 NA Red 5SPD |
uvachief
How can you tell if your ac control unit is working properly? Is there a bench test you can do?
uvachief
bump
all you do is get a can of refrigerant with UV leak Detection..then you shine a blacklight to find the leak.
93 964 87 944 88 944s sold (gone but not forgotten) |
An auto-parts store should have it.
unindicted co-conspirator
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
uvachief
Can anyone point me in the right direction for step by step instructions for removing and replacing the condenser? Mine has a small leak in it. Anyone try any of that "seal a leak" in the can? I see dozens of them in auto stores and few have been written up in collector mags such as Interdynamics EZ Chill R-134a Refrigerant Plus Oil with Leak Sealer (18 oz.) or Red Angel A/C Stop Leak? I hate to go through pulling the old one and replacng with a used one only to have the same problem 30 days from now. Worth trying these sealant kits for $40 or just bite the bullet, sell my old used one and buy a new one for $250?
Sincerely, uvachief ![]() 1986 944 NA Red 5SPD Last edited by uvachief; 04-25-2012 at 07:49 PM.. Reason: typo |
Proprietoristicly Refined
Adding link with answer by member kuehl to complete post if anyone else has this problem and searches.
A/C Compressor On and Off John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
uvachief
Charged the system again while hunting for the green dye under ultraviolet light. Small leak became a big leak. It appears to be the seals in the couplings where refrigerant line 944 573 197 08 connects to the condenser. Heard a small hiss while checking that soon became louder and refrigerant started bubbling out. Before adding more refrigerant, bubbles were noticeably present in the drier sight glass. I think it is o-ring part 999 707 250 40. There was green dye on the condenser but right wehre the connection was to the refrigerant line. Compressor had a small trace of green dye where refrigerant line 944. 573 091 03 connects to the compressor. Thinking that o-ring is bad as well. Same part number as the other one. Odd thing is that the a/c shop that got my system up and running in May of 2010 allegedly replaced all the o-rings. I had purchased an o-ring kit from Pelican and they may have used half the o-rings in it. Guessing they missed these 2. If I crack open the system, do I need to replace the drier again? Pelican shows 2 that fit my car. Cheap one for $11 and one for $59. I couldn't get the cheap one to fit last time. Was too tall. Headlights would not go down and would rub on it.
uvachief
Don't get how the a/c shop could have failed to have replaced these o-rings in 2010. I installed a new remanufactured compressor at that time. I had air for 2 summers. Guess you really do need to run your a/c once a month or the seals will rot.
AFM #725
You do not need to replace the drier, just the o-rings.
uvachief
This just gets better and better. Not just the seals and o-rings. The high pressure switch is covered in green dye. Cheap fix. The compressor has some green dye on it but it is mainly right where the clutch is. The condenser has a whole bunch of green dye along the bottom where the refrigerant line connects. More than just the o-ring seal. The service port is also leaking. I could throq a bunch of used parts at it or pick up a new condenser, lines and high pressure switch for about $450 with tax and shipping. New compressor would be another $500 or so. Does anyone make their own lines from the condenser to the compresor and compressor to the evaporator? They are complex so maybe the Pelican prices are not bad after all.
AFM #725
Eeek. When I went to get my A/C recharged I was just going to delete the A/C if there were any major leaks.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Thread Tools | |
Rate This Thread | |
Tags |
a/c , air conditioning , compressor , leak |
