Routing the O2 sensor cable on the 951?
Is there a special trick to routing the cable from the 02 sensor in the 951? There are exhaust pipes everywhere and I can't remember where the cable was routed originally. I'm worried it will melt if it ends up against one of the pipes.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 05-24-2011, 10:19 PM
Arizona_928's Avatar
It will melt if it hits the down pipe. I spliced my universal aftermarket 02 sensor with the original harness so it gave some extra length to route it. I routed mine over the brake master.
dolor et pavor
Copyright
Old 05-31-2011, 11:03 AM
I think I have routed it properly, behind the AOS heat shield lower lip and around the back of the AOS.
Old 06-04-2011, 11:31 AM
In the Fires of Hell.....
kdjones2000's Avatar
Yes, underneath the heatshield for the downpipe. It usually goes just in front of the AOS, but going behind it should not affect anything.
Cheers, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-04-2011, 12:01 PM
