Sway Bar Options
I am looking at upgrading my sway bars that are on my 86 with Option M456.
I have ruled out the weltmeister for now due to budget, but want to upgrade from the 23.5mm front and 14mm rear that are on there now. I have decided to go with the 5 way adjustable 19mm rear from Lindsey racing, but I am not sure what to do with the front to go with the 19mm rear.
Also, I am switching to steel a-arms and wondering if I need anything else when switching to a larger front sway bar? Are the retaining clips the same size? and will they fit in the steel a-arms with no issue?
Thanks!
Old 06-17-2011, 08:00 PM
flash968's Avatar
i'd grab a set of stock 968 sway bars - 26.8mm front and 16mm rear - you should be able to get them both for under $100
Old 06-17-2011, 09:11 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
The 19mm rear bars fit well with the 26.8 front sways as found on the 88 turbo S and 89 Turbos.
It's been quite awhile since I've worked on the early bars but I think the mounting hardware is different between the steel arms and the later aluminum ones
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 06-17-2011, 11:21 PM
I have the 26.8 front and the Lindsey 19mm with solid mounts and adjustable drop link. The set up works well and the car is very balanced. I also have Bilstein sports all around, #350 Ground Control coil overs on front and 28mm torsion bars rear. I really like the set up.
Old 06-18-2011, 07:04 AM
smokin_944's Avatar
Cocacolakidd is right. With the steel A-arms on the front you need 2 stabilizer brackets, 944.343.735.00 (left) and 944.343.736.00 (right). Then you are good to go.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 06-18-2011, 07:29 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Bamf3000
You could always upgrade to a 16 or 18mm rear without the $$ big expense.
Tighten your rear a little....
I have a 968 16mm Rear setup with Grease-able Poly body bushings & Endlinks for a good price.
PM Me if your interested & Please visit my garage...
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-19-2011, 04:00 PM
Once I get past my rear main seal, clutch job, I am installing the Lindsey bar with the 26.8 bar in front. I have new Konis for the rear but will not have the larger torsion bars or the GC/Koni coilover and 350# springs for the front yet. Hopefully it will not be too unbalanced for my track session this weekend (if I make it in time ! )
Old 06-21-2011, 12:00 PM
