1983 porsche 944 STUMPED!
First and foremost thank you for allowing me to join this amazing forum full of expertise and helpfull posts, ive been a reader for about 3 months now but as of today i became a member because i dont know anyone that can help me with my 944! ive always owned lowriders so this has been the biggest change for me.
okay. it ran great everyday. then one day i pulled over to use the phone (shut car off) after talking, it wouldnt start. opened the hood and the possitive battery lead was smoking. after further investigation and a long walk home to get my tools i re connected the positive lead with a cleaner, uncoroded section of the positive lead. bang! she fired up and ran great. then one night, later after driving all day. it wouldnt start. just kept turning over! juice didnt seem to be the problem because it was a steady turn over (no dieing battery sound ) realized vacum hoses were extremly old and brittle when i checked on and it broke at the T by the fuel pressure regulators. i replaced those, checked the spark plug lead for spark, and nothing happened. i put a skrewdriver in the end and put it close to a ground. also couldnt hear the fuel pump very well. as its just me fixing it so i have to try and start it aswell. ive removed air cleaner and checked the acv? i think its called? (the plate that can get gunked up over time )
any suggestions? please help shes my daily driver and i dont want to part with it!
thanks again
sorry if i sound completly unknowing lol
sincerely chris
Old 06-29-2011, 07:38 PM
SLED GUITARIST
Dan Himan's Avatar
Smoke at the hot lead, any loose wire around the battery area, the alarm horn is there and some people will cut the wires and they will short. Also the dme is at the foot of the passenger side. Some people will cut the alarm wire (bad) and leave them to eventually short. i had this happen on my old 85.5 944, burnt from the fuse box to the alarm box near the DME.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 06-29-2011, 09:14 PM
well thanks alot man, youve helped with the tedius task of locating the DME without a guide book.and no loose wires at the battery cable. 3 seperate side connecters plus positive lead but i will trace it. Are DME relays easy to obtain ? im in BC so will local parts shops be able to get ahold of these parts? so far ive just found parts threw parted out cars
Old 06-29-2011, 09:39 PM
SLED GUITARIST
Dan Himan's Avatar
I usually pick up extra DME realys at pick in pull. Not sure if you have of those there. Look in the Parts for sale section here. Parted cars are a good source. I all ways check for any thing that does not look stock, wires cut and not going to anything. You can all ways use a voltmeter to see if there's power in the cut line.
Old 06-29-2011, 11:42 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
your DME is NOT in the passenger footwell, it is above your shins when sitting in the driver's seat, bolted to the bottom of the steering column.
your fuse box is under there as well... enjoy learning to become a contortionist!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 06-30-2011, 07:28 AM
yea swapping out a fuse or even worse a relay on early 944 is a major PITA!!
Old 06-30-2011, 07:32 AM
SLED GUITARIST
Dan Himan's Avatar
Ahh thats right Pre 85. Removing the steering wheels helps some. Removing the seat helps alot.
Old 06-30-2011, 10:12 AM
ERAU944's Avatar
I just didn't want to see him rip up the passenger carpet looking for something that isn't there
Old 06-30-2011, 10:17 AM
haha too late to be honest, didnt rip it but pulled it up in search, ive found dme relay i think, its in the number 2 spot from top left on relay panel? says its for the fuel pump, but i removed it and it had DME on it . i opened up the black case to check sauder points and everything seems fine car lost juice from trying to start it for so loong so i have to wait till this evening when a new battery + charger arrives. so far ive cleaned all terminals, alot of grounds and checked the dme / fuel pump relay if thats even where it was :S another question! where is the fuel pump located so i can try and see if its getting power? when i put key in and turn ignition i cannot hear its excessive buzzing so i assume its not getting any power:S hrmm so stumped... its been the best running/ handling car ive ever laid my ass in and also walking to work at 630 am is getting annoying lol. i dont have an ohm meter or any power readers im using a headlight bulb and wires so this is pretty backyardish. any other suggestions for testing or a way to override the dme? to see if thats the pesky lil problem?
Old 06-30-2011, 05:25 PM
also just cracked the fuel line at front and it didnt spray like pressure releasing it gushed out, i closed it, re cranked the car and it gushed out the same as before, if the fuel pump wasnt working would the line be empty ? or and would the fuel resevoir at a lower spot or would it stay in the line upto the top of engine
Old 06-30-2011, 05:51 PM
ernie9944's Avatar
[QUOTE=83porsche944 :S another question! where is the fuel pump located so i can try and see if its getting power?
Don't let them guys get to you ,changing fuses & relays on an early 944 is simply good & healthly exercise.The fuel pump #29 is located in the rear(passenger side)up beside your spare tire cubicle.Here a diagram of all your fuel lines including pump & filter. #13/Fuel filter -#27 the filter inside the tank which if glooged can cause fuel delivery problem.Good Luck.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 06-30-2011, 06:11 PM
wow thanks for the info man! and also do you guys know what this is?
[IMG][/IMG]
i hit a bump hard the other day and maybe the hard plastic just shattered, its behind the oil fill and it runs to a black boot that goes to my tranny? or bottem of engine any ideas if this could be the culpret?
Old 06-30-2011, 06:43 PM
and this is my baby lol
[IMG][/IMG]
Old 06-30-2011, 06:47 PM
700 bucks
Old 06-30-2011, 06:48 PM
response to that is i guess it would be really difficult once you get old and rickety im a youngin lotsa juice left its eazzyyyyy
Old 06-30-2011, 06:50 PM
That vaguely looks like the connector for the 02 sensor....
No spark but your getting fuel?
When you crank the car does the Tachometer move at all? It should jump about 200rpm's...
if this doesn't happen then check the connectors for the speed and refference sensors...
The connectors are VERY close to the broken connector you posted a picture of. 2 identical looking connections, black and rectangular....
Make sure they are still connected.
Early 1985 944.
I like Bacon
Old 06-30-2011, 07:02 PM
omg are they black and about an inch by a half an inch? like black plug case that is supported by a metal bracket?
Old 06-30-2011, 07:07 PM
and also the two wires in the bottem right of the photo go to a black plug that is also disconnected]
Old 06-30-2011, 07:08 PM
[IMG][/IMG]
Old 06-30-2011, 07:22 PM
ernie9944's Avatar
[QUOTE=Truckin4life;6110490]That vaguely looks like the connector for the 02 sensor....+1 it's the connector for the 02 sensor.
Old 06-30-2011, 08:44 PM
