Toofah King Bad
Rasta Monsta's Avatar
Originally Posted by aj951 View Post
i installed the wled-5 units from superbright about 4 years ago and they work fine with the dimmer.
+1
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-07-2011, 06:19 PM
aj951's Avatar
Tell me AJ, do they dim like before or just at the top range of the dimmer? Also when you dim do they dim ok to start with then suddenly cut off?
9FF,
They dim just like the OEM incandescent bulbs and use the full range of the dimmer potentiometer. They do not cut off, even at the full dim position.
A.J.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 11-08-2011, 05:40 AM
All Spooled Up
9FF,
A.J.
Excellent! It's good to hear that they do operate within the full range of the pot.
I CAN vouch for the fact that manufacturing tolerances, slash quality control, currently lies somewhere between horrible and non-existant at this stage of the LED game. I recently purchased 10 E27 base replacements for household bulbs, and 2 of them did not work, right out of the box. That amounts to a 20% failure rate. You just have to put up with that for now, I suppose. But that number has got to improve, as time goes by.
Old 11-08-2011, 02:16 PM
9FF 9FF is offline
9FF's Avatar
It seems that the WLED-5 dim the full range so the tunnel lights are fine. Problems must start when the other instrument lights get swapped out as they are all on the same dimming circuit.
I did all mine at once so I had no reference as to which LEDs actually caused the dimmer to stop functioning correctly.
Old 11-08-2011, 03:23 PM
