83 NO START STRANDED Quick reply?
Hey all my new to me 944 an 83, died while I was driving, I tried a new DME relay that I had, and nothing, pulled a wire and it is arcing, the Tach does bounce and it does build oil pressure when it cranks, it just cranks and cranks, with the old relay it fired ran a little maybe 2 seconds then died right out again. I just towed it to my shop, any input or ideas are appreciated, could the fuel pump just go like that? I have the 924S to drive still so the 944 can sit for a little while
Mark S. Certified Porsche Newb Alea Iacta Est. 1987 924S 67k miles, all stock besides weltmiester Throttle Cam 87 944 Turbo shes got a few goodies. New DD |
Thanks JR I'll give it a shot, think maybe I can test the fuel pump with a volt meter?
I wouldve never thought about the FPR, perhaps when I got on the high way the FPR built up pressure to keep up with the high RPMs and then didn't lower when I started cruising... I'll have to give that a peek.
Proprietoristicly Refined
Early 944 owners have more under dash wire problems.
Clarks would suggest to clean the fuse contacts, grounds. Wiggle the DME 35pin plug and wires to see if there is a bad connection. A cracked ignition switch is a possibility and cheap to replace. Pelican Parts - Product Information: 111-905-865L-M5293 Clarks has the DIY info GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Dumb question....but is there gas in the car?
Nope it has plenty of gas, and no visible fuel leakes
Comeau Racing
"I tried a new DME relay that I had, and nothing, pulled a wire and it is arcing,"
That's kind of important. Elaborate? Don't dig too deep too soon.
PCA since 1985 77 924 MARTINI Edition rescued,SOLD 88 924S Special Edition rescued,SOLD Comeau Racing Enterprises, Inc. www.comeauracing.com We do only 924S, 944's, 968's all day, every day. |
you should always check the flywheel sensors if you have a no start with the engine turning. Look to see both ends and give them a wiggle, one at a time if you can, to see narrow your search for the bad part. Allways remember... look for the most simple answers when trouble-shooting 944
Do you have any problems with your battery box leaking? Mine was leaking and I patched it up. However, after having a no start problem just like yours a few months later, my DME was ruined due to the inevitable water damage that occurred when the BB was leaking. May be worth a check FWIW.
Thread Tools | |
Rate This Thread | |
