i wasn't trying to sidetrack the thread, left out all the details, and was merely pointing out that it is easy to spend that much money.
but, to answer the questions asked: first off, it's about 100lbs heavier than the 968 engine, even with the bang zoom all aluminum motor he used, not 40 or 50. you have to factor in all the other stuff that goes with it, not just the engine. not the end of the world, but definitely threw off the balance. as for driving poorly, everything about the way the car drove was a mess. tons of power in a straight line, but useless. the chassis couldn't handle it. everything that made the 968 what makes it what it is, was lost. it felt like an old vette. the hydroboost system SUCKS!. you have no sense of the car stopping. the engine has too much torque for the torque tube assembly. you can feel the shaft flex. really nasty feeling, but you wouldn't know it unless you were familiar with what it is supposed to feel like. the clutch was incredibly insensitive, and you couldn't use first gear at all (and he was using the turbo box). the chatter was horrible. he used the bang zoom stuff too. basically it spent every dime to do it right, took it to the leading expert in the country on these conversions, and still ended up with a bucket of bolts. i now return you to hopefully what will be a better build, if only by avoiding some of the problems of somebody else |
That Guy
ugh
![]() Please just stop posting in this thread. After years of reading your posts on RL, Pelican and whats left of the 968 forum, i have zero interest in any of your input. You seem to have one opinion on the LS swap, so we get the point. Yet you cant offer any details whatsoever on this car you drove other than how ****ty it was. Feel free to start another thread where you can discuss why an engine swap shouldnt be done.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 10-21-2013 at 04:54 AM.. |
That Guy
The radiator from Renegade should have shipped last week, so work on the intake setup can start once that comes in. The shop said they finished up the fuel lines, wiring on the engine side, battery cables and also completed hooking up the brake lines to the Ford master cylinder. Unfortunately i am offshore for a few weeks, but looking forward to seeing the progress when i get back!
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
This is looking awesome. Hoping for a video when it's running!
I'm planning one of these swaps as well, already have a shell of a car that I'll be using and decided on an LS1 engine. I'm collecting parts over the winter and will hopefully start building it with the help of some friends in the spring. I may message you with questions as my project progresses.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928 Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944 |
NY944Turbo
John,
If you pass the White Plains area I would like to take a look at the car. Or maybe I go meet you, really interested on the whole setup. |
your average wrencher...
Keep your head up John, I've read a lot of your posts over the years too and realize you get into something and you DO get things done. Correctly.
I'm still tuned in...
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
There is an ignore button. Profile, user lists, add to ignore list. Effective.
Great work by the way. I used to have half baked rh 944 lt1. Brakes were higher pivot point. Sucked. Brothers stock mustang gt 1998 brakes felt just ok. Not sure what the solution is, but read all of tony g posts. He races so much, his suggestions have to work. I wish I could have that much track time....
That Guy
Here is some more progress over the past month. The radiator took a bit longer to arrive than expected so that held up a few things. But the wait was worth it i think. Shop said it fit well and it made the hose routing much easier.
Just a few more things left to finish, hopefully it will be ready to start before i leave again in a few weeks .To be finished.. -Wire in fuse block for the PSI engine harness, tach signal, VSS..etc. -C6 vette intake setup -Hoses for coolant expansion tank -Power steering lines -Oil lines -Exhaust from headers to cat-back -Clutch master cylinder hookup, just waiting on 1 fitting so we can connect AN to the quick disconnect on the throwout bearing ![]() ![]() I hope to have the car back by the end of the year, so i can spend the rest of the winter working out all the bugs. By spring time id like to have it mostly sorted out. Your more than welcome to check the car out whenever.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 11-16-2013 at 01:11 PM.. |
Excellent work Jon, that engine looks like it grew there. Beautiful
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
That Guy
Porsche 944 Turbo LS1 Swap - YouTube
Its freaken loud! 4" all the way back from the long tubes with a Magnaflow muffler. I may have to get something more quiet.. but for now i can live with it! The only thing left to finish is the intake. Getting everything under the nose panel (in particular the MAF) has been a pain due to the clearance between the radiator and hood. Just waiting on a filter which should be here monday (i love Amazon Prime!). ![]() The rear section was off so a v-band could be installed to make removal easier. Everything fits amazingly well. ![]() Hope to be able to bring the car over to the other shop for the alignment next week. A big hopeful is to have the car home by the 2nd week of January. Then i can start playing around with it ![]() I sat in the car for the first time in a while today also. Felt a bit alien considering ive been driving my pickup and a E36. Pedal feel on the brakes was good, though the clutch will need some adjustment made. The pedal was surprisingly pretty light which i wasnt expecting. It was a bit spongy and the travel on the pedal was a little short. Needs to be bled again and hopefully can adjust the linkage / push rods enough to get the travel to my liking.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 12-26-2013 at 02:01 PM.. |
AKA J BERK on Rennlist
Jon
Looks fantastic! Best Joe
Joe Current: 2014 Cayenne S Gone but missed: 2003 996 C4S; 1991 944 S2; 1984 944 NA |
winter-hater club member
sounds amazing!
strong work!
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Really nice work man, I wish I was that inclined to do a build like that.
That Guy
Everything is done! Just cleaning up the engine harness wiring under the dash and doing some long overdue rust cleanup on the battery tray.
Jon
Fantastic! Best Joe
Misunderstood User
Jon,
You have help me a few times. I enjoy and honor your ability to share your knowledge and respect many of us who contribute to this board. I admire your attention to detail and doing it right. I hope the car meets every expectation you planned. And if it doesn't, I know you will analyze the problem and fix it - it is the mark of a good engineer and craftsman. I admire your work and passion. Good luck with your new ride. You inspire me and I hope many others. All the best Jon!
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
JRW
944 ls
That is some serious 944-porn. Incredible work. Just beautiful.
That Guy
Put about 9 miles on her earlier and filled up with gas for the first time in 2 years.
Looking forward to the weekend .![]()
Garage Helper
Absolutely gorgeous - What of the handling with the NA motor in there ? Please let us know how the handling feels when you have a chance ...
.....Ricers beware.....
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
