Fastest you've driven?
What's the fastest yall have driven your 944s? How did it feel at that speed? Was it still pulling when you let off?
AFM #725
120.. It was sweet
Flat out on the Nurburgring, each lap.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
Incorrigible
I've seen 120 in the 951. Obviously, plenty of power left to go. Felt very similar to 85 for smoothness, except for wind noise. Id love to see faster speeds on a track, there just arent any safe places to do that on public roads, just a bad idea, I wont do that anymore.
Ive seen 135 in a muscle car, absolutely no comparison to the 951.
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
150+ flat out in the blue 968 the day i got it. definitely not the fastest i've driven though (208 in a daytona charger - twice - very scary)
I was 18 and dumb. Did 120 in my N/A and cruised at that speed for about 7 minutes. Felt so smooth, wind noise was a bit high. On my way home, my exhaust fell off due to crap welds (not by me). It felt like it had a little more, but not too much. I wouldn't do it again unless it was under perfect conditions (i.e. long road that I could see straight ahead, no traffic either way, sunny, dry...etc.)
86 944 N/A (red) |
I saw 135 in my S2, sat right on a 951 starting from 80.
130 several times and only once managed 140 going uphill
,the laws of physics were malfunctioning that day
Catalin '86 DD |
Toofah King Bad
Probably 110-ish on the race track, still pulling good in fifth.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
your average wrencher...
155. gps verified
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
GorillaFoot
In my 951... 150mph, windows down, on a very wet Daytona Speedway track. She was still pulling pretty hard when I had to brake for turn 1.
1989 951 Track car. Cayman GT4. Suncoast PCA Chief Tech Inspector. |
~110 on dry-rotted tires in the 944.
100mph for nearly 30 minutes on a roadtrip following a cayenne in my bmw. |
First of all let's not get all work here about how fast we had our cars going. Cruising speed of over a 100 mph are probably an every days recurrence on the German Autobahns(Porsche homeland) depending on the car you own,here in the US & Canada we make big fuss out of it because we are simply not use to driving that fast since our hwys speed limit are so restrictive.We are simply not use to that kind of speed (unless on a race track).First to cruise that fast don't matter which models Porsche you own go got to have a car in tip top mechanical condition (motor/suspension/tires & brakes).A car you can trust on the staigth & through curves.In a period of over twenty six years had the chance to drive my ex 944 at over 130 mph many many time without drama & the car felt very safe.The 968 over 156 mph (still had some left in her) in a control area once again without drama & the car felt very sturdy at that speed.Mine you concentration when going that fast is a must ( like mention because we are simlpy not use driving that fast).Here is a pic of my 968 speedo showing 210 klms(about 130 mph) on an open stretch of road.And I had enougth confidence in my car to hold the steering with one hand & take the pic holding the camera in the other.Notice that the pic is pretty clear (not blurry the car has no shake at any speed & the suspension/ tires is doing the job which it is was meant to do) I can only say that going over 150 mph is not something I will do every days but if I were driving on the autobahns cruising at 100/120 mph with a well sort out 924S/944/S/S2/951/951/968 could be done without a sweat,it will just be a matter of paying more attention at what is going on around you.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
something else to remember is that the speedometer is not the way to tell how fast you are going. many speedometers read high, increasing as speed increases. how much varies from manufacturer to manufacturer
as an example, according to a magazine review, and verified by many other cars i've seen, the 968 speedometer reads high, and by the time you get to top speed it is about 11mph fast, which means that an indicated 150 is really about 139, and when you hit top speed in stock trim, while you are going 156, it will read about 167 or better |
dkbautosports.com
my 2146 LBS LS7 powered 944 was clocked at 173 MPH it has more but there is not a long enough straight at the track were they were useing a radar gun . there is not speed-o in the car it adds to much weight .
my EX944 spec car with now a SBC motor tops out at 156 in a draft about 152 in open air out af a draft . |
My 83 NA stopped at 120 exactly. Drive it at that speed for about 5 miles in California. The road was straight and clear for like 10+ miles. My NA I had years ago I did 135. Did any of them come with a governor? I thought it was weird that it stopped at exactly 120mph.
Just seen your post after I posted mine.You must have suicide tendency plus you don't care about other peoples life driving your car at 110 mph on dry- rotted tires.Driving fast can be done two way (SAFELY) or (RECKLESSLY).Sorry to be so blunt about it but I really think you belong to the second categories.As for following a Cayenne for half an hour at 100 mph I also have my doubts about that.
136 on my IQ3 Data logger at Daytona for the club race. I don't think there was much left.
Did 128 later in pouring rain where you couldn't see 20 feet in front of you. Miserable racing conditions. But you can stick on the banking well over 100. Not bad for a stock engine, short fifth NA.
Brent K SP1 944 |
Banned
135 on the GPS in my n/a which seemed to match 100% with the dash speedo
