ae1969's Avatar
Send a message via ICQ to ae1969
central locking system failing?
Has any one had a central locking system fail?
and where is the central locking system located? The light goes on, when I hit the switch, but there is no clicking on either side?
Where is it hiding, and how would you trouble shoot this thing.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-08-2002, 10:48 AM
AFJuvat's Avatar
It does happen, albeit very rarely.
Before I would jump to the central locking system, I would check for a bad fuse/relay, followed by the switch itself for failure, then the microswitches, and then the central locking system.
If memory serves, the central locking system is located under the drivers side dash.
AFJuvat
Old 06-08-2002, 05:56 PM
ae1969's Avatar
It does seem like it may be the relay..........
Whats odd......It has been acting up, after I wash it!! Religiously.
I wash it, I drive it home....and the locks pop open, then they close.........its like they have a mind of their own.
Strange....that it would act up after being washed.
Old 06-09-2002, 07:58 PM
If it happens only when you wash the car I would suspect the plug connector for the microswitch on the door lock. Remove the door panel and follow the thick white wire from the door lock to the connector; you might find it is corroded.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-10-2002, 09:41 AM
ae1969's Avatar
Thanks brit.........I will pull it out and see what I find...
ALex
Old 06-10-2002, 10:50 AM
