pearldrum's Avatar
Send a message via AIM to pearldrum
Porsche Crest I need an idle adjustment screw
ok, so I was raising the idle speed on my car (it was at 600RPM) I had the wrench and started turning the idle screw under the cam and the head snapped right off, barely any pressure. So, does anyone have one of the adjustment screws with the nut on it for an '83, or know where I can get one?
also: the bolt head was 8MM, but does anyone know what size the actual bolt is, like how think the shaft is? I need to know to drill it out....
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 06-21-2002, 06:40 PM
AFJuvat's Avatar
Short of finding a throttle body at a junk yard, I am guessing the dealer will be your best bet.
You may want to try 20th street auto in phoenix AZ, they have a lot of hard to find used 944 parts
http://www.20thstreetauto.com
AFJuvat
Old 06-21-2002, 10:15 PM
pearldrum's Avatar
do you think I would just be able to use a bolt with a nut on it for locking it?
Old 06-22-2002, 07:19 AM
SoCal Driver's Avatar
Have intake with charred throttle body. Will take a look today if screw and lock nut is removeable.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-22-2002, 09:21 AM
pearldrum's Avatar
Porsche Crest
nevermind, thanks though. I got it fixed. We put some WD-40 in it and then i drove it some, got back home and the rest of the screw was gone. Went to a hardware store and got a 5MM screw with 2 lock-nuts. put it in and it fit...
Old 06-22-2002, 09:37 AM
