Dex/Merc instead of Dexron III for Power Steering?
Hey All - What's a good replacement for Dexron III for my '87's power steering fluid? Everything I've read says our cars take Dexron III but I can't find it in stores anymore...Dex/Merc being one replacement.
For the time being, I just need something for topping off (found reservoir leaking) and later flushing.
1987 924S 5 Spd 1979 Jeep CJ7 3 Spd |
AFM #725
Where are you located? I've seen generic dexron III replacement at all local stores
A couple of possible replacements compatible with Dexron III are Dexron IV or Synthetic ATF such as Deep Purple.
Deep Purple may cause Smoke...on the water!
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
it will turn you into a smooth operator.
I'm using (Superpro RXL1 ATF+3) from Chrysler without any issues.It's the same as Dextron III which is a GM product.
The autozone replacement says it's compatible for cars that require dex3 but I don't know if I should be mixing that in
Toofah King Bad
Redline D4 is Dex III compatible and very robust.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
AFM #725
If it says for DEXRON III applications it's probably good. I am using generic no name O'reilly's store brand dexron III ATF and it works.
1988 944 2.5L 8-v NA 301k
So I had to sign all the way into my Peli forum account just to post my hearty laugh on that one..
Thought the same thing.. Good on ya mate. ![]()
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
thanks for all your comments
...once last thing, so is it okay to mix/top off with the old, or should I flush it out? at least at a minimum, perhaps I'll draw out as much as I can with the baster I just bought.
Flush it.
Proprietoristicly Refined
Your choice on use but I am not comfortable with any leak sealer in the PS unit. ![]() Also on the recent trip to WalMart Superstore found they did not carry any 20-50 conventional oil. Most all oil was synthetic --mostly 10-30 or 10-40 in various brands. Not even Pennzoil 10-40 for the Jeep. John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Regarding the 20W50...I've never found 1+ quart sizes in stores for this type, only 1 quart. Recently bought 3 oil change size jugs on Amazon (Castrol GTX)
Repeating my answer for the post: Castrol Info on Dex/Merc: Castrol USA - Transmax DEX/MERC The AutoZone fluid you found is OK if it says compatable with Dexron III. And for the Synthetic members: https://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx# J_AZ
From the bottle backs (underlined parts I reference above): Standard - "Recommended for use in all 1983 to 1996 Ford automatic transmissions. Use Castrol Type F ATF in applications calling for Type F. Do not use this ATF in applications calling for Mercon V, Mercon SP or Mercon VI." For Honda, Toyota, Nissan, and Other Imports - "Recommended for use in vehicles that require: Honda, Acura - ATF-Z1, DW-1 (except in CVTs), Toyota, Lexus - Type T, T-III, T-IV, Nissan, Infiniti - Matic-D, Matic-J?, BMW - LT71141, Mitsubishi - Diamond SP-II, SP-III, Volvo (all specifications) .....Also meets requirements of: ATF+3, ATF+2, ATF, Ford Mercon, Ford Mercon V (Not for use where Mercon SP or Mercon LV is required), General Motors Dexron III and prior (Not for use where Dexron VI is required)."
Thanks Todd,
I bookmarked the post. J_AZ
Thread Tools | |
Rate This Thread | |
